It is currently Thu Jul 19, 2018 11:41 pm
 Post subject: Insulating a Shed
PostPosted: Thu Aug 10, 2017 7:26 pm
Has thanked: 3 times
Been thanked: 2 times
Hello peoples of UHM :huray:
Sorry for this "newbie" question. I've never really worked with insulation an' whatnot. Basically, I would like to insulate my shed. How would I do this? :scratch:
I have a ton of Kingspan (assorted sizes) and plasterboard in my garage. Would I need a vapour barrier? I would like the shed to be well insulated.
Basically looking for any advice people can give.
James
 Post subject: Re: Insulating a Shed
PostPosted: Thu Aug 10, 2017 10:27 pm
Has thanked: 673 times
Been thanked: 1934 times
heeelllooo james :welcome: :welcome: :welcome:
outer cladding breathable membrane 15-20mm airgap insulation then internal cladding
anything less than 50mm thickness will be poor level off insulation
For this message the author big-all has received gratitude : is an idiot
PostPosted: Fri Aug 11, 2017 9:05 am
Has thanked: 13 times
Been thanked: 181 times
:withstupid:
I agree with big-all!
As you say you have lots of insulation off-cuts, you can improve the insulation layer by creating a 'sandwich' of different thicknesses!
davyp1
PostPosted: Fri Aug 11, 2017 9:06 am
Thanks! :huray:
Just to clarify, is the breathable membrane stuck directly to the cladding? A few forums I have read have said that the breathable membrane should always go on the hot side of the insulation - is this true?
James
PostPosted: Fri Aug 11, 2017 11:42 am
Been thanked: 92 times
breathable membrane on the cold side
vapour barrier on the warm side.
In practice for a shed its not really very practical to use a breathable membrane. the easiest thing is to fit the insulation between the studs leaving a gap to the cladding. Then on the inside use foil tape to cover all the celetex joints, go over studs where necessary. If you make the silver a complete cover that will act as your vapour barrier.
Thats assuming your kingspan is PIR insulation with foil face not polystyrene
For this message the author Notch1 has received gratitude : is an idiot
PostPosted: Fri Aug 11, 2017 12:02 pm
Thanks! :huray:
