It is currently Mon Feb 19, 2018 12:13 am
Visit Thermo worx
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
PostPosted: Sun Jul 23, 2017 4:16 pm
Has thanked: 3 times
Hi,my porch door is catching in the middle.how can i pull the door in so it doesnt catch?top and bottom are ok so ive no idea what is going on!its happened before and my builder did it in 5 mind but im clueless.been searching online but cant find any advice when its the middle catching.i think the door may have dropped slightly as locks are not ligning up either.any help appreciated thanks
PostPosted: Sun Jul 23, 2017 6:28 pm
Been thanked: 92 times
Upvc or timber?
For this message the author Notch1 has received gratitude : multiman
PostPosted: Mon Jul 24, 2017 9:04 am
Upvc
PostPosted: Mon Jul 24, 2017 10:49 am
Has thanked: 123 times
Been thanked: 133 times
Have you checked that all the screws that hold the locking mechanism in place are screwed in fully and have not loosened a bit?
When you check for this , do it from both sides of the door as you open an close it in case you can see something else that may have come loose.
If the door has mushrooms as part of the locking mechanism then these can unscrew a tad causing the door to catch as you describe.
If you can post a few pictures of the door and lock that may help us find a solution.
Mike
PostPosted: Mon Jul 24, 2017 9:12 pm
Thankyou will post pics tomorrow
PostPosted: Wed Jul 26, 2017 6:51 pm
Right have lifted door as much as possible so how do i adjust the mushroom things?thankyou
PostPosted: Wed Jul 26, 2017 7:03 pm
sorry took me a while to add a photo as kept saying too big but how do i adjust this bit?these bits are what keep catching,thanks
PostPosted: Wed Jul 26, 2017 7:17 pm
Has thanked: 1388 times
Been thanked: 3544 times
Chances are it'll be the part that that "catches" in that needs adjusting ... a sorta U shaped part. Pics of that please,
Or the door needs toeing/heeling...
PostPosted: Wed Jul 26, 2017 7:31 pm
these are the only pieces that stick out and move up and down when handle is moved.cant see anything else sticking out that could catch?
PostPosted: Wed Jul 26, 2017 8:09 pm
Has thanked: 363 times
Been thanked: 1307 times
It'll be on the frame - opposite the "mushrooms" on the door.
It's what the "mushrooms" engage with that you'd have to adjust, (if that's what actually needs adjusting).
PostPosted: Wed Jul 26, 2017 9:22 pm
theses are where the mushroom things go
PostPosted: Wed Jul 26, 2017 9:33 pm
its actually these bits that the mushroom things are catching on.im not sure what their purpose is?
PostPosted: Wed Jul 26, 2017 10:08 pm
Loosen the screw on the plate that the roller is catching on and slide it up or down a couple of mm and see if that makes a difference. It may take a little bit of fiddling but it must be something simple like that or the door has dropped and the hinges may need a tweak.
When you move the plate mark where it was originally before making a adjustment.
Mike
PostPosted: Wed Jul 26, 2017 10:13 pm
Thankyou i will try moving the plate tomorrow as i spent 4 days tweaking the hinges and ive pulled it up as far as it can go.my builder spent 5 mins adjusting it last winter but i never asked him what he did.will report back tomorrow but do these plate things need to stay on?thankyou
PostPosted: Wed Jul 26, 2017 10:25 pm
Before you look at the keep, give the roller a quarter turn with a Allen key in case it is a little proud and therefore catching on the keep.
Mike
For this message the author London mike 61 has received gratitude : multiman
