It is currently Mon Jun 18, 2018 2:45 am
PostPosted: Tue May 23, 2017 11:26 am
Has thanked: 1 times
Been thanked: 3 times
First of all forgive my ignorance of all things electrical.
I thought I'd have a go at putting a strip light in my garage and although I think I've wired it correctly, the fuse in the fuse box keeps tripping meaning something must be wrong.
I've made a diagram of how I've wired it and I was wondering if anyone could see any glaring errors.
Any help appreciated:
https://goo.gl/photos/ZkFj1VJW4XAM2zXC9
PostPosted: Tue May 23, 2017 5:55 pm
Has thanked: 43 times
Been thanked: 1265 times
Assuming the earth and neutral are NOT in any way connected to the switch, then the problem must be in the light.
Picture of both please.
(Oh, and where is the supply taken from)
For this message the author someone-else has received gratitude : sajeel
PostPosted: Tue May 23, 2017 6:36 pm
Hi someone-else and thanks for replying.
The two neutrals in the switch itself are just connected together by one of these things (sorry, don't know what they are called)
http://mnats.net/images/avel-lindberg_secondary_ct_wiring_thumb.jpg
Inside the switch there is a little brass screw and clamp that I assumed the earths went to, so I attached the incoming earth feed and the outgoing earth feed to that. Could that be the problem?
Sorry, I don't have pics since I'm no longer at the property at the moment.
For this message the author ives31 has received gratitude : sajeel
PostPosted: Tue May 23, 2017 7:01 pm
Has thanked: 3 times
Been thanked: 19 times
You've wired the switch wrong, neutral doesn't go through it and you're creating a short circuit.
Take the neutral lines out and connect them with a terminal block (the ones in your photo) and do the same with the earth. Switches don't usually have an earth terminal (unless they have a metal face). *
Connect the incoming live to "Com" and the outgoing live to L1. That should work
* However, if you've bought an isolating switch, then it should say "Feed" and "Load" next to the terminals, for live and neutral and there will be an earth. If that's the case, the the incoming live goes to "feed L" and the incoming neutral to "Feed N". The the outgoing connections go to the load side.
If you can photo the back of the switch it will help a lot.
For this message the author Stooby2 has received gratitude : sajeel
PostPosted: Tue May 23, 2017 7:04 pm
thanks man...much appreciated
PostPosted: Tue May 23, 2017 7:13 pm
It's still not the correct way to wire the light & switch and I'd recommend you get an electrician in to sort it for you properly.
PostPosted: Tue May 23, 2017 9:46 pm
What you say is true, however i asked about that and the reply is
If that's choc bloc then yes it is correct.
ives31, need more pictures.
PostPosted: Tue May 23, 2017 9:50 pm
Has thanked: 145 times
Been thanked: 213 times
"It's still not the correct way to wire the light & switch and I'd recommend you get an electrician in to sort it for you properly."
It's OK provided the OP takes into account the caveats and comments from other members above*. This way of wiring a light, although less common than the "usual" three plate system, is quite acceptable but is quite often used for lofts,garages and sheds etc. I think the method is called "loop in switch".
*ie. The neutral in is connected to the neutral out ONLY and not to anything else. Ditto earth.
PostPosted: Tue May 23, 2017 9:58 pm
Approved Electrician
Has thanked: 162 times
Been thanked: 561 times
ives31 wrote:
You fitted three lights in your garage back in 2015. Have you moved house?
PostPosted: Wed May 24, 2017 3:26 pm
OnlyMe wrote:
ives31 wrote:
No I didn't manage to do that job. It's been on the backburner for a while. I tried recently and couldn't get it to work so I thought I'd ask again.
PostPosted: Wed May 24, 2017 7:07 pm
Still need pictures.
PostPosted: Thu May 25, 2017 5:07 pm
Has thanked: 1443 times
Been thanked: 3683 times
Pics as asked. switch wiring, wiring at light and where it's fed from.
PostPosted: Mon Jun 05, 2017 12:57 pm
Code:
Get. An. Electrician. In.
You clearly don't know how to do the job. Get an electrician in to do one set of the lights, ask him to show you what he's doing as he does it. Then you'll know how to do the others properly.
PostPosted: Mon Jun 05, 2017 12:59 pm
I've already done it myself. Didn't need an electrician.
