It is currently Sat Jan 19, 2019 12:52 am
PostPosted: Mon May 22, 2017 8:25 pm
Has thanked: 4 times
Been thanked: 8 times
Could I bend 9mm plasterboard to a sharp curve of around 4" 90 degrees?
I've got a solid former to bend against and fix in the form of a curved corner post. The pieces of board will be approx 12" high. This is for a bulkhead below a ceiling.
I thought I could try a combo of cutting back of board and damping to get the curve?
What is the solution for beading the bottom edge?
PostPosted: Mon May 22, 2017 8:30 pm
Has thanked: 3 times
Been thanked: 92 times
You could try this
http://vcut.co.uk/services/flexiboard/
PostPosted: Mon May 22, 2017 10:52 pm
Has thanked: 13 times
Been thanked: 182 times
:withstupid:
It's the obvious solution, Flexiboard is the way to go . . . .
davyp1
PostPosted: Wed May 24, 2017 10:07 am
I'm assuming the 'bottom edge' you refer to is a reflex angle!
In that case (or with an angle other than 90, you would use a
'thin skim stop bead'.
https://www.google.co.uk/search?hl=en&s ... mdfMdlaMKE
davyp1
