It is currently Tue Sep 25, 2018 4:34 pm
 Post subject: Rotten wood repair
PostPosted: Mon May 08, 2017 8:52 pm
Any suggestions on how to repair this please.
Nothing to technical.
Thanks.
Its at the front of my Victorian gable end.
Its a rotten section of facia on the front of my Victorian gable end. Aboutthe size of a average tv remote control.
I was going to post a photo but it says my pixels are to high.
 Post subject: Re: Rotten wood repair
PostPosted: Mon May 08, 2017 9:11 pm
Has thanked: 84 times
Been thanked: 224 times
Sounds like a simple splice would suffice , cutting out the rot plus a bit extra to get back to solid timber then fit in a new piece and paint in. An alternative , although one I've not really had much to do with , is treat , wood hardener and fill.
As you say it's quite a small section but it is on the facia of a gable end , the actual repair wouldn't take that long but it will involve erecting a tower scaffold I would have thought.
PostPosted: Mon May 08, 2017 10:56 pm
Has thanked: 692 times
Been thanked: 1952 times
is this visual or actual damage :dunno:
if you havent been up there for a prod you wont the full extent off the damage
PostPosted: Mon May 08, 2017 11:08 pm
Has thanked: 13 times
Been thanked: 182 times
Thanks.
You could reduce the size of your Picture in PAINT so you could upload it!
davyp1
PostPosted: Tue May 09, 2017 8:07 am
Heres a photo
PostPosted: Tue May 09, 2017 10:34 am
have the tiles on top been removed :dunno: :dunno:
if not that set up will always fail with rot and damp ingress
PostPosted: Tue May 09, 2017 10:52 am
Thanks for the photo.
Taking the righthand side of the photo first,the top part appears to have been repaired.
Noting a small amount of rot in the bead just below, this also needs cutting out and
replacing with the same section of molding. The section removed being used as a pattern for the new!
The same procedure also applies to the left hand side.
Cut out the rotten moldings to good timber and cut at 45deg (same angle as the hip rafter.
Using the molding sections removed as patterns for the replacement sections required, mark
out the mitres with a mitre square (or use a sliding bevel).
Apply a coat of wood primer to all new timber.
Pin all new sections in place, sinking pin heads to below surface of the wood.
Use exterior wood filler to pin holes and where required.
Apply undercoat/Gloss paint to areas of repair.
davyp1
PostPosted: Tue May 09, 2017 10:55 am
I missed that big-all!
But did wonder where the gutter was?
davyp1
PostPosted: Tue May 09, 2017 11:13 am
very hard to tell :lol:
