It is currently Sat Jun 23, 2018 9:32 am
PostPosted: Sun May 07, 2017 1:19 pm
Has thanked: 20 times
Hello there
I have asked a similar question before, but this is a different Issue
I have a 5m x 7m Shed going up,
I am wanting to do foundations myself this time,
Foundation will be a strip foundation, concrete base dug in and either foundation blocks or brick on top, Ground is hard packed type 1 with 200mm(ish) soil and grass that's been there for a few years
I will be using 6x2 joists@4.8m(400mm spacing) and 4x2 studwork,
My question is..
As its 5m wide how many strips of foundation would be recommended, ??
Goose
PostPosted: Sun May 07, 2017 1:49 pm
Has thanked: 13 times
Been thanked: 181 times
If you buy 47x145 C16 timber, the maximum span between foundation walls is 2.83 Metres.
Therefore you would require three foundation walls (one either side set in from the end and the third central to the other two)
Cheers,
davyp1
For this message the author davyp1 has received gratitude : Goose
PostPosted: Sun May 07, 2017 1:53 pm
Kiln dried C16 regularized treated joist will be used
Once again
PostPosted: Sun May 07, 2017 2:13 pm
Once again
Just a point, 47x97 C16 has a maximum span of 1,71 Metres; but would require
Four(4) supporting foundation walls.
If you chose to put in an extra foundation, you could save yourself a few bob on timber.
Cheers,
davyp1
PostPosted: Sun May 07, 2017 3:04 pm
Has thanked: 3 times
Been thanked: 92 times
If its over 30 sq metres internally, I guess it falls under building regs?
PostPosted: Sun May 07, 2017 4:06 pm
Correct Notch1, and if it was slightly under, I guess it would not!
PostPosted: Thu May 18, 2017 7:41 am
Thanks for the help so far
Joists are done, now ready to start framing
Question now is regarding the framing
Help please
I have been given two bits of advice,
1. Frame out walls before laying ply sub floor,
2.lay ply sub floor then frame walls
Any advice here would be great
Goose
PostPosted: Thu May 18, 2017 10:01 am
Indeed!
I just mentioned it in case the OP had overlooked that and 5.0m x 7.0m could be over..........
PostPosted: Thu May 18, 2017 12:22 pm
Notch1 wrote:
Indeed!
It was a good point Notch :-)
PostPosted: Thu May 18, 2017 12:34 pm
Help please
Goose
Hi Goose,
I would probably do it as follows:-
Draw up a working drawing - All elevations + door window sizes etc
Cut & make up all frames
Board floor area (to drg dims etc.
Place & prop the Front frame + screw/nail through sole plate
Place & fix next elevation (working clockwise)
Place & fix remaining elevations
Place & fix rafters/purlins etc.
Place & fix door/s & windows
Board walls
Board roof area
Fix roof covering + rainwater goods
Hope that helps some . . .
davyp1
PostPosted: Thu May 18, 2017 12:46 pm
Has thanked: 380 times
Been thanked: 1370 times
Goose
If you frame the walls first, you'll need extra joists along two sides to take the edge of the ply floor.
For this message the author ayjay has received gratitude : Goose
PostPosted: Thu May 18, 2017 1:12 pm
davyp1
I have all drawings and details
However you have aswered a couple of other questions i had
Thanks again
ayjay
Never even thought about that,
Once again,
thats the reason I ask
cron
