It is currently Sat Jan 19, 2019 10:52 pm
PostPosted: Thu Apr 20, 2017 2:54 pm
Has thanked: 7 times
Been thanked: 1 times
Hi. I am painting a rendered wall and the render beads are rusty but still stable. What would be the best solution to sort these before applying masonry paint other than replacing them with plastic beads. Thanks for your time
PostPosted: Thu Apr 20, 2017 3:55 pm
Has thanked: 13 times
Been thanked: 182 times
While you could wire brush the rusty areas and then paint with 'Gavlvafroid' paint, it is my feeling that it would be better to replace the beads with either Plastic or Stainless.
PostPosted: Thu Apr 20, 2017 10:15 pm
Has thanked: 19 times
Been thanked: 8 times
How would you remove the beads without wrecking the render?
PostPosted: Thu Apr 20, 2017 10:33 pm
Small Grinder & Diamond blade. Cut down each side of the corner about 15cm in
and carefully break out the corner rnder with hammer & bolster.
PostPosted: Fri Apr 21, 2017 1:50 pm
Has thanked: 100 times
Been thanked: 122 times
On several jobs I've tried Kurust, Aquasteel, Zinsser bin and oil undercoat on rusty beads after cleaning them off, in all instances the rust stains reappeared after 12 to 18 months.
For this message the author ian gibson has received gratitude : bits&bobs
PostPosted: Fri Apr 21, 2017 3:55 pm
Has thanked: 755 times
Been thanked: 843 times
Zinsser BIN is of no use in this instance. No good for exterior use (but for knots on wood).
PostPosted: Fri Apr 21, 2017 4:17 pm
I know, after seeing rust converters fail over time, and oil undercoat, I thought why not give it a go on another job, lasted about a year before the rust stains came through again. In the words of Neil Young, "rust never sleeps".
PostPosted: Fri Apr 21, 2017 4:43 pm
Has thanked: 244 times
Been thanked: 247 times
Has anyone tried coverstain?
I always thought hammerite would do the job then painted over.
PostPosted: Fri Apr 21, 2017 4:49 pm
I think the problem is that the render covers most of the bead so whatever you put on it, it's not really getting at the underlying rusting steel. I know builders who still use galv beads on externals instead of stainless or plastic just because they are cheaper, drives me round the twist.
PostPosted: Fri Apr 21, 2017 5:58 pm
Yes think that is bang on. Gonna go with plastic beads which will definitely do the trick
PostPosted: Fri Apr 21, 2017 5:59 pm
Thanks everyone for your input
For this message the author bits&bobs has received gratitude : ian gibson
PostPosted: Fri Apr 21, 2017 7:43 pm
In my first post to your thread, I did suggest Galvafroid as a solution but also confirmed that I personally would replace the beads with Plastic or Stainless.
I just thought it prudent to let you know that it is my feeling with the correct preparation that you could get four years or more, by treating just the rust areas with Galvafroid I will outline the necessary prep as follows:-
    Using an 1/2" Cold Chisel, remove the render from the rusty areas (obviously you can only expose the external face of the bead)
    Wire brush all rust areas
    Rub down all rusty metal exposed with fine sand-paper or emery cloth.
    Apply Galvafroyd as per instructions on the tin (my feeling is two coats)
    After 48 hours apply 2 coats of Unibond (PVA) Diluted as stated on the can, 2nd coat just before render repair.
    With the render repairs being all small and quite tight, I would suggest you use silver sand mixed at 4:1 by volume (you can buy bags of this that Pavoirs use dry).
    If your existing render is a smooth finish, you should be able to blend it in using a sponge.
Replacing all the beads is a mamoth task, the above would give you a stay of execution if you need it!
Cheers
https://www.google.co.uk/webhp?sourceid ... galvafroid
Users browsing this forum: spottie and 2 guests
