It is currently Wed Apr 24, 2019 5:50 pm
PostPosted: Tue Apr 18, 2017 8:47 am
I've changed over a few sockets and switches in the living room, and the dimmer switch seems to be making a loud buzzing/humming noise when on. After some time it also slightly overheats - it's hot to the touch but not uncomfortably warm. I didn't think to check the various options before buying it, just assumed that one type suits all.
Looking it up on Google, I'm reading contradicting advice - ie that the heat is safe and dimmers are prone to being warm depending on how many bulbs it's operating, but then reading elsewhere that it can be a fire hazard through time.
There are two other dimmer switches in the flat which also make a buzz, but not as loud as this one, and definitely not as warm as this one gets.
So, is it safe? Will it cause issues through time? Should I upgrade it? The dimmer is operating about eight spot lights. It's just the cheap white one, so if I need to change it to a more suitable one I don't mind - would anyone know what type I'm needing?
Thanks.
PostPosted: Tue Apr 18, 2017 9:07 am
UHM Super Moderator
Has thanked: 180 times
Been thanked: 621 times
I'll move this to lighting in a mo.
PostPosted: Tue Apr 18, 2017 9:22 am
Has thanked: 349 times
Been thanked: 1829 times
Simple answer is to add up the wattage of all the lights the dimmer is controlling.
Compare that figure with the rated power of the dimmer itself.
Ideally (this is a personal thing) I'd not allow the dimmer to control more than 50% (half) of its rated power. So a 1000W dimmer should be loaded to 500W maximum.
Heat is fine - it's a by-product of what the dimmer does and, yes, the more lights you dim the warmer it gets. It should NEVER get too hot to touch though!
PostPosted: Tue Apr 18, 2017 10:06 am
Okay thanks, what about the buzzing noise? Is that standard?
PostPosted: Tue Apr 18, 2017 10:27 am
Has thanked: 41 times
Been thanked: 1470 times
buzzing is usually cheap components in dimmer.
What are you dimming? Not all lights can be dimmed - specifically the "transformers" if you have halogen 12v halogens.
PostPosted: Tue Apr 18, 2017 10:54 am
There's an inductor (coil of wire wound on a ferrite former) inside some dimmers and if the windings are loose they have a tendency to vibrate (hum/buzz) - the more you load it up, the more it makes noise. Sad side-effect of cheaper units.
