It is currently Mon Oct 22, 2018 8:58 am
 Post subject: Cracks in plasterboard
PostPosted: Mon Apr 17, 2017 8:45 pm
Been thanked: 2 times
Hi guys,
My mum moved into a new build 20 years ago and the house is beginning to show it's age. Some of the plasterboard has cracked on the walls presumably at the joins.
What is the best way to treat this problem before painting? Form whay I've read, sand-fill-sand is the suggested answer. Is this right?
Thanks,
Andy
PostPosted: Tue Apr 18, 2017 8:12 pm
Has thanked: 239 times
Been thanked: 1105 times
Do you mean Easifill
PostPosted: Tue Apr 18, 2017 11:15 pm
Has thanked: 734 times
Been thanked: 806 times
He means the process I think. Sand, then fill, then sand again. But as I am not into plasterboard joints I cannot suggest if the joint could do with some very fine scrim tape.
PostPosted: Wed Apr 19, 2017 3:57 pm
Has thanked: 13 times
Been thanked: 182 times
You need to open up the crack slightly using say the corner of a scraper or old chisel, removing any loose material as you go.
Lightly sand over the crack to remove any proud material, then fill using a fine surface filler.
The previous prep is to give the filler a little depth to key into.
Lightly sand down the repaired crack which should be hardly visible.
Then commence painting.
