It is currently Wed Feb 21, 2018 12:58 pm
Visit Thermo worx
 Post subject: power tools
PostPosted: Fri Mar 31, 2017 12:20 pm
Has thanked: 1 times
Hi all
have just singed up a new member!!!. I,m hoping someone out there can help me with an issue with the "Titan" 4 in 1 multi tool (hedge trimmer/ pole pruner/stimmer/brush cutter.).
I bought this "used" item recently from toolstation. my problem is, I can't work out how to attach the extension pole to the pole saw or the hedge trimmer as at either end of the extension pole it has a sqare bar inside the pole which means that when the extension is attached the sqare ends come into contact with the sqare ends of the the other attachments?. Should there be a female fitting in the extension pole?.
or am I just being thick and it will run properly fitted this way. needless to say I have not tried to use it yet. Anyone got any advice. Thanks. Doughboy.
 Post subject: Re: power tools
PostPosted: Fri Mar 31, 2017 12:31 pm
UHM Super Moderator
Has thanked: 45 times
Been thanked: 80 times
:welcomeuhm:
I've sorted out the double post for you. Some photos might help.
For this message the author moderator7 has received gratitude : douhghboy
PostPosted: Fri Mar 31, 2017 5:58 pm
Has thanked: 44 times
Been thanked: 191 times
There is an instructional manual for a titan 4 in 1 on available for download on screwfix as a pdf if that helps. It just looks like a locking pin that needs to be inserted and tightened on the diagram but says there is a cover. Might be a different model of course
http://www.screwfix.com/p/titan-ttk587g ... tool/48423
PostPosted: Fri Mar 31, 2017 6:10 pm
Thanks, I will down load the maual and give it another go. Fingers crossed!!
