It is currently Sun Jan 21, 2018 4:24 am
Visit Thermo worx
PostPosted: Sat Mar 25, 2017 7:42 pm
Been thanked: 3 times
Hello everyone,
Recently moved in to a new flat and the radiator in the kitchen has been painted with what I believe to be Matt Emulsion, it's a complete mess and I have no idea how to fix it to make it look normal. I know it will need to be glossed but is there any thing else I need to do?
Please see the pictures attached.
Any help and advice would be greatly appreciated.
PostPosted: Sat Mar 25, 2017 8:01 pm
Has thanked: 160 times
Been thanked: 5 times
You will need to sandpaper or use paint stripper you could also use heat gun to burn off paint, then clean and use enamel radiator paint it's not easy to use and drops a lot so you have literally watch it dry for a nice finish
sent using tapatalk
PostPosted: Sun Mar 26, 2017 4:51 pm
sent using tapatalk
Thank you for the reply, I think I will use a heat gun, god knows how many layers are going to come off.
For this message the author kianDonoghue89 has received gratitude : sajeel
PostPosted: Sun Mar 26, 2017 5:22 pm
Has thanked: 587 times
Been thanked: 681 times
:welcomeuhm:
If it is emulsion it may come off with loads of water and a bit of rubbing ... with scotchbrite type stuff perhaps. You don't want to take off the original paint. With a heat gun (try it by all means) you will have a job removing paint from the grooves and I am not too sure heat works on emulsion the same way it woks on oil based paints.
For this message the author OchAye has received gratitude : sajeel
PostPosted: Sun Mar 26, 2017 5:41 pm
Has thanked: 1358 times
Been thanked: 3512 times
OchAye wrote:
:welcomeuhm:
Heat gun is not the way to go as och-aye say's..
http://www.diy.com/departments/diall-pr ... 7QodNXQClQ
(other retailers available) are useful.
Then either a dedicated radiator enamel or gloss. (bear in mind that oil-based gloss will yellow over time)
PostPosted: Sun Mar 26, 2017 6:35 pm
wine~o wrote:
OchAye wrote:
:welcomeuhm:
<span class="skimlinks-unlinked">http://www.diy.com/departments/diall-profiling-sanding-sponge/261779_BQ.prd?ecamp=Seapla&ppc_type=shopping&ds_kids=92700018899003427&gclid=CI3NmvTN9NICFQcz0wodqJYIvg&gclsrc=aw.ds.ds&dclid=CIaqt_TN9NICFSqr7QodNXQClQ</span>
OchAye wrote:
:welcomeuhm:
Thank you both for the reply, I will give it a go and see if it will come off with some water, I have no idea why someone would paint it with emulsion.
PostPosted: Sun Mar 26, 2017 11:29 pm
I recently had the same problem (friend's new office and I volunteered). Three radiators, one yellowed (it had been painted but with oil paint) two certainly had emulsion, perhaps more than one coat and the same soft sheen dulux trade emulsion had been used on doors.
The emulsion came off the doors whilst trying to smoothen it with wet and dry paper. Once it got some rubbing and a lot of soaking it just came off the door. One of the emulsioned radiators (on the 3rd or so coat of paint) decided to bubble up ... most of it peeled off but enough bits stayed to make it a b@st@rd to strip clean by sanding.
IF you can abrade the paint whilst you are keeping it dripping wet you have a good chance of the paint coming off relatively easily.
PostPosted: Mon Mar 27, 2017 12:00 am
Has thanked: 453 times
Been thanked: 1518 times
You can try this to see if it works as I have used it on light fittings and the like that were splodged with emulsion. Paint a small test area with fresh emulsion leave it for 20 minutes and then give it a scrape. The solvent in the new emulsion helps to soften the old stuff and it will reactivate it. I do not know if it will work on a baked on emulsion painted on a radiator but worth a shot.
Painting with BIN
For this message the author dewaltdisney has received gratitude : sajeel
PostPosted: Mon Mar 27, 2017 6:47 am
Has thanked: 12 times
Been thanked: 38 times
If your handy with the spanners, depending on the size new rads aren't that expensive
For this message the author p4ult has received gratitude : sajeel
PostPosted: Tue Apr 11, 2017 7:15 pm
I managed to get it off with some hot water with a bit of flash in it, luckily it was only one coat!
Arm is really killing me now though!
:cheers:
For this message the author kianDonoghue89 has received thanks - 2: dewaltdisney, sajeel
PostPosted: Tue Apr 11, 2017 8:08 pm
Some scrub and rub with elbow grease
