It is currently Tue Oct 23, 2018 5:17 pm
 Post subject: Bubble in vaneer?
PostPosted: Thu Mar 23, 2017 3:28 pm
Has thanked: 1 times
Hey guys
Was just about to start painting my door which i had assumed was solid wood and i find this bubble in it.
I assume this is veneer? I was just going to cut it out with a Stanley knife then fill the hole it leaves but was wondering if anyone could suggest a way to minimise the amount of filler needed to make a neater job of it.
 Post subject: Re: Bubble in vaneer?
PostPosted: Thu Mar 23, 2017 3:53 pm
Has thanked: 44 times
Been thanked: 696 times
Make a cut, squirt in glue and then clamp flat?
PostPosted: Thu Mar 23, 2017 4:20 pm
Has thanked: 610 times
Been thanked: 1740 times
I did a small veneer bubble by squirting some PVA in a pin hole and putting a hot iron on. The iron heated the water out of the glue and it bonded. There was a small bump left afterwards which was 'tenting' caused by the wood expanding. In this instance I think I would slit right down the middle with a thin craft knife and try the PVA /hot iron approach. You might have to trim the veneer edges back alomg the slit as you go to eliminate tenting. :thumbright:
Painting with BIN
For this message the author dewaltdisney has received gratitude : sajeel
Users browsing this forum: Rorschach and 1 guest
