It is currently Fri Feb 23, 2018 6:09 am
Visit Thermo worx
 Post subject: Rotten fence post
PostPosted: Mon Mar 13, 2017 8:57 pm
Has thanked: 4 times
One of my fence posts has become rotten at its base. I have removed the post but it has left about 6-8 inches of wet rotten wood in base. It is proving difficult to remove it. Has anyone any tricks up their sleeves to remove this?
 Post subject: Re: Rotten fence post
PostPosted: Mon Mar 13, 2017 9:01 pm
Has thanked: 170 times
Been thanked: 101 times
I do this often. If it's concreted in you'll need to break that up to help dig the rotten bit out. If not concreted then simply dig round it and it will come out eventually. I use post hole diggers, spades and a large wrecking bar to help loosen the area up.
PostPosted: Mon Mar 13, 2017 9:54 pm
Has thanked: 493 times
Been thanked: 1561 times
Often it is suction that is holding it in. I had a wooden post like that and I broke out one side of the concrete fill and still could not lift the stub out. I screwed a coach bolt in the side of the stub and used an hydraulic car jack to force it up and out. When it came clear there was a slurpy pop as the suction released. As K says breaking out the concrete is often the only way to go.
Painting with BIN
For this message the author dewaltdisney has received gratitude : Denis0603
PostPosted: Mon Mar 13, 2017 10:02 pm
Has thanked: 505 times
Been thanked: 98 times
What are you going to replace it with?
Has thanked: 41 times
Been thanked: 579 times
I big drill bit (a cheap spade bit will do) and a corded drill is usually a fast and fairly low effort way to remove material, especially rotten wood as it will chew it up easily.
For this message the author Rorschach has received gratitude : Denis0603
PostPosted: Mon Mar 13, 2017 10:25 pm
Has thanked: 71 times
Been thanked: 167 times
I've keep a long drill bit of around 7/8" in the van for jobs such as this. It's understandably not my best drill bit as you're always going to catch the concrete at some point. Drill a load of holes and then split it up with an equally second best chisel , it does become increasingly easy as more is removed. I do find that it is an easier operation with 4" posts rather than 3" simply because you can get your hand in to pull out the rubbish. It doesn't always work though and in some cases or if you have no access to power I then dig out to the side and break away the concrete but try to leave as much as possible in place because this often helps with locating and holding the new post.
For this message the author Grendel has received gratitude : Denis0603
PostPosted: Mon Mar 13, 2017 10:33 pm
Has thanked: 953 times
Been thanked: 1775 times
I've removed them by screwing a 4ft piece of 4x2 scrap into the broken/rotten post and putting a couple of bricks under making a kinda see-saw and levering the post out.
For this message the author steviejoiner74 has received gratitude : Denis0603
PostPosted: Tue Mar 14, 2017 10:15 am
A 6x6 post.
