It is currently Fri Jan 18, 2019 1:42 am
 Post subject: UPVC Door Pannel
PostPosted: Thu Mar 09, 2017 6:42 pm
Hi there,
Trying to change bottom of PVC door panel havening no luck in getting it out to measure it
inside the beading is black rubber but will not come out is there some technique that am not using?
has black rubber stuff on the outside of the door as well am I meant to try take this out first? :help:
Thanks for any help!!
 Post subject: Re: UPVC Door Pannel
PostPosted: Thu Mar 09, 2017 6:51 pm
Has thanked: 70 times
Been thanked: 84 times
Every one is different depending on age , if the beading is on the inside then some doors have a wedge gasket you remove on the out side first then this gives you room to get beads free. Some have a captive gasket on the out side and a wedge on the in , remove wedge ect, some have a captive gasket out side and captive gasket on the bead also, these the bead is removed using a stiff scraper type tool that you insert in the join between the door and bead. It comes with experience in telling which system you have , sometimes the gasket is that old it's so hard to remove
PostPosted: Thu Mar 09, 2017 6:59 pm
I have attached picture of the front and back of the door is it case of just getting the scrapper underneath the black rubber moving it up and down till it comes lose
File comment: Front of door
File comment: Back of the door
PostPosted: Thu Mar 09, 2017 7:05 pm
Hi looking at the picture it looks like the gaskets are captive to the frame and bead ( hard to tell from a picture for sure ) I would try putting the scraper between the bead and the frame on the long edge . Withe the scraper inserted leaver the scraper away from the bead you should get movement and a gap , once you have started it , it becomes easier and once the first one is off the others come off easier , 2 sides removed first then top and bottom . Pay attention to how they clip into the frame as this will make refitting easier
PostPosted: Thu Mar 09, 2017 7:27 pm
Has thanked: 1509 times
Been thanked: 3834 times
Probably an idea to remove the catflap before as well...
PostPosted: Tue Mar 14, 2017 1:16 pm
Has thanked: 1 times
That was really a great idea u have shared. It was really helpful and thanks a lot !!
