It is currently Thu Sep 20, 2018 1:47 am
PostPosted: Tue Mar 07, 2017 10:23 pm
Has thanked: 54 times
Been thanked: 23 times
Hi all, just after some advice.
Last room to decorate is the living room of an old cottage and just above the skirting boards the original paint is peeling / flaking off.
I've bought some peel stop and just wondered on the recommended procedure to repair these walls before final coats of fresh paint.
Do I scrape back the flaky paint, then sand... and then apply the peel stop to the affected areas. THEN use a smooth filler (jointing compound?) over the dried peelstop.
THEN paint?
thanks
Dave
PostPosted: Wed Mar 08, 2017 6:50 am
Elephant Man
Has thanked: 601 times
Been thanked: 1357 times
You named it on one. Exact procedure there. :thumbright:
Nihil expectore in omnibus
For this message the author dynamod has received gratitude : davemulheran
PostPosted: Wed Mar 08, 2017 7:16 am
Thanks for the confirmation :)
PostPosted: Wed Mar 08, 2017 8:52 am
Has thanked: 873 times
Been thanked: 470 times
Exactly as you said. A small amount of Peel Stop goes a long way so it's worth painting the Peel Stop over more than just the affected area as if there is any loose paint that you can't yet see, the tackiness of the emulsion is likely to pull it off.
For this message the author Tom d'Angler has received gratitude : davemulheran
PostPosted: Thu Mar 09, 2017 5:04 pm
Hi guys thank you.
OK so it looks like the previous owners of the house did NOT mist coat to seal the plastered walls and (only on the lower 1/4 of the walls I can litterally strip the paint off the plaster.
Im getting to the parts where the paint seems to have adhered. Now do I....
1) painstakingly strip ALL the paint from the affected walls?
2) reach the adhered sections and then sand the edges of the paint, peel stop the edges then easy fill the expanse of exposed plaster to flush up against the adhered paint
Im thinking 2!
What a pain in the backside!
PostPosted: Thu Mar 09, 2017 5:53 pm
Elephant Man
Given what you describe, I'd be for trying to get it all off, provided your sanity can handle it. :mrgreen:
You might be able to remove small stubborn areas with an orbital and some P60-ish grade abrasive. In reality, it may be a case of getting as much off as a scraper will shift, and Peelstop the bad areas, then flush, but............any potential high spots this technique creates, may show up in strong directional light - hence trying to get it all off.
See what the light in the room is like. It may be OK to flush off any bad bits and they won't be noticeable.
PostPosted: Thu Mar 09, 2017 6:31 pm
I would be tempted to do what you said in number 2 and then put a coat of Peel Stop over the whole wall, just in case there's another area that hasn't shown up yet.
