It is currently Sat Feb 17, 2018 8:58 pm
Visit Thermo worx
PostPosted: Sun Mar 05, 2017 12:06 pm
Hi All,
I've moved into a bungalow which has had a annex extension built onto the side. It's a truss roof 8meters span.
I would like to remove all the internal walls and relocate with stud walls. There are no supporting walls running against the timbers which have blocks all the way the roof timbers.
I didn't know if I should put a steel in on the safe side or it's just a waste of time and expense.
Here's a few pics to better explain.
Any advice would be appreciated.
PostPosted: Sun Mar 05, 2017 1:20 pm
Has thanked: 42 times
Been thanked: 76 times
A floorplan would help.
Colin
PostPosted: Sun Mar 05, 2017 4:57 pm
Has thanked: 1388 times
Been thanked: 3544 times
Colin
As would a structural engineer. :shock:
PostPosted: Sun Mar 05, 2017 6:10 pm
Has thanked: 13 times
Been thanked: 8 times
You would like to or have removed all the walls??
Just asking ;)
DIY - Joining things together to make stuff ;)
https://ddmetalproducts.co.uk
PostPosted: Sun Mar 05, 2017 7:35 pm
Just asking ;)
Yes some were already down then when I discovered the the walls weren't connected at all I thought get them down and make a head start to clear the decks.
I seems a huge span to me to have no support but it has been built like that so not sure if it's a ticking time bomb or would be ok.
I wasn't sure if anyone else has had a similar experience.
My thoughts at the moment are edge on the side of caution and get a steel in and maybe consult a SE on size of beam.
PostPosted: Sun Mar 05, 2017 7:45 pm
I think your thoughts are the right way to go IMHO ;)
Thats a pretty big span - roof tiles heavy Redland's by any chance? Could be a lot of weight up there.
PostPosted: Sun Mar 05, 2017 10:26 pm
I agree Dave, yes they sure are Redlands.
The annex will have been up around 15years plus so I'm really surprised it's not given in already.
Thanks for the feedback I've got a SE coming out Wednesday so I'll let you know the outcome.
PostPosted: Mon Mar 06, 2017 3:49 pm
Has thanked: 94 times
Been thanked: 282 times
The outer wall might be tied into this non load bearing partition wall and as such provides stability you might need to leave a tied column for that reason, but as said above a floor plan, and picture of how the W truss is tied to the wall, if it has been up for 15 years it should have been done correctly.
PostPosted: Fri Mar 10, 2017 4:19 pm
Afternoon all,
We've got the all clear, the internals are non supporting as suspected. Better to be safe than sorry thou.
Thanks for the replies.
