It is currently Thu Sep 20, 2018 1:46 am
 Post subject: Electrical back box
PostPosted: Tue Feb 28, 2017 11:56 am
Has thanked: 3 times
Been thanked: 6 times
I need to surface mount a back box into my wall however the cable won't be recessed into the wall and therefore the 'punch out holes' aren't going to work.
How can a drill a hole into the back box so I can feed the wire into it?
I've tried a number of different methods but keep snapping the back box
Any tips?
 Post subject: Re: Electrical back box
PostPosted: Tue Feb 28, 2017 4:18 pm
Has thanked: 210 times
Been thanked: 143 times
The plastic boxes have small break off tabs that are removed for cable access
PostPosted: Tue Feb 28, 2017 6:04 pm
Yeah I know about those but there are never any (in the ones I use) that let you run a cable out the bottom and straight down the outside of the wall.
Am I just being thick?
PostPosted: Tue Feb 28, 2017 6:07 pm
They all have that.Image
This is a double, break a tab and run cable down wall through trunking if you wish.
PostPosted: Tue Feb 28, 2017 6:43 pm
Has thanked: 52 times
Been thanked: 544 times
you could use a pvc back box (trunking/conduit box) then you can drill a hole to suit with no risk of shattering it
eg. http://www.wickes.co.uk/Wickes-2-Gang-P ... m/p/715009
As in the pic above there are 3 opening just simply clip out the tab(s) with a pair of pliers/cutters, and just tap out the bit on the inside
PostPosted: Tue Feb 28, 2017 6:53 pm
For this message the author Bob225 has received gratitude : Ktuludays
PostPosted: Tue Feb 28, 2017 7:41 pm
Bob225 wrote:
Says it all really
PostPosted: Tue Feb 28, 2017 8:48 pm
Bob225 wrote:
Literally exactly what I was wanting to know
