It is currently Wed Jan 16, 2019 2:25 am
PostPosted: Fri Feb 24, 2017 7:40 pm
Has thanked: 1 times
Hi.....Anyone know what type of thread on this bosch grinder is, it's a bosch GEB 1000 CE...been sat in garage for a while, can't find any type of attachment that will attach onto it in order to use it???
Any help or advice appreciated!!
PostPosted: Fri Feb 24, 2017 7:56 pm
UHM Super Moderator
Has thanked: 56 times
Been thanked: 92 times
:welcomeuhm:
Moved to Tool Talk
PostPosted: Fri Feb 24, 2017 8:05 pm
Has thanked: 223 times
Been thanked: 169 times
That type of knurled shaft is normally used as a press fit with another item. I suspect that the tool fitting part has fell or broken off
For this message the author Ktuludays has received gratitude : randallsglasgow
PostPosted: Fri Feb 24, 2017 9:22 pm
Has thanked: 696 times
Been thanked: 2013 times
yes my thoughts where perhaps a large plastic /rubber disc or component moulded on from new that has now broken off :dunno:
PostPosted: Fri Feb 24, 2017 10:37 pm
Has thanked: 408 times
Been thanked: 1482 times
https://www.google.co.uk/search?q=GEB+1 ... 80&bih=536
PostPosted: Sat Feb 25, 2017 7:59 am
Makes sense guys...sounds like it may be for the bin unfortunately, because yes, the shaft is built into the unit....if i knew a way of fitting an attachment to it then it would obviously be worth keeping, shame as it's in good nik otherwise...
Thumbs up
PostPosted: Sat Feb 25, 2017 10:38 am
Looking at the pic below, (taken from one of the pics on my link), there's no shaft on the tool and a set of accessories with shafts.
PostPosted: Sat Feb 25, 2017 12:10 pm
Cheers for that ayJay...i took one last attempt in having a look inside & with a bit of fiddlin about i managed to release the spindle of the suggested broken attachment that was lodged in...it now looks clear to fit a new sander or grinder attachment...pain in the **** that was...should have taken a video before taking apart...took me about an extra half hr trying to figure out where the parts went back in....
Thanks all...if not for your responses, i prob wouldn't have bothered having a second go.....Thumbs up.
PostPosted: Sat Feb 25, 2017 8:10 pm
Has thanked: 104 times
Been thanked: 354 times
Have you managed to get any new bits to go in?
Had one kicking about at work years ago, took almost like an SDS shank tool iirc.
The bit you had stuck in looks like the mandrel of a flap wheel that has disintegrated.
Use the colett type on smaller ones or M14 thread (same as angle grinder) on everything else.
