It is currently Wed Feb 21, 2018 1:08 am
Visit Thermo worx
PostPosted: Thu Feb 23, 2017 12:45 pm
Has thanked: 1 times
Hi everyone,
I make chocolate from bean to bar and I would like to make my own cocoa butter press.
I have the plan but I need someone to make a custom metal part which would look like a very large piston. I tried to contact some machinist but without success. Is it because It is not what they do? Who would I need to contact?
Thank you very much in advance for your help
Thomas
File comment: This would be the base of the press, easy to find
File comment: This is the whole machine, what I need to be made is the piston
File comment: Who could make this for me? What kind of skill work do I need to contact?
PostPosted: Thu Feb 23, 2017 2:54 pm
Has thanked: 2 times
Been thanked: 1 times
That's basically a car pump jack on a stand.
All you need is your measurements and go down to your local steel stock holders and buy them cut to the length you want and either drill the bolt holes yourself or a small engineering firm would probably do it for you.
For this message the author Steveuk23 has received gratitude : thomasnowsun
PostPosted: Thu Feb 23, 2017 3:28 pm
Has thanked: 38 times
Been thanked: 1179 times
I am wondering does thomasnowsun mean the silver bit in the 2nd picture? as the big red bit is a "20 tonne hydraulic shop press"
similar one Click here
PostPosted: Thu Feb 23, 2017 3:43 pm
Has thanked: 328 times
Been thanked: 1707 times
Anywhere that make pipes/flanges could deliver the bottom part of the press. It's only a short cut-off length of stainless pipework with a sealing plate bolted to the flange - presumably drilling a few holes in it to allow the oils to flow out would suffice or maybe doing so around the edge of the flange???
The plunger part is again stainless made from stock with a nylon disc cut to a slide-fit. This is something any competent lathe user should easily accomplish.
Try a facebook plea locally - but if you can source the materials in advance it would make someone's decision to assist you that much easier.
PostPosted: Sun Feb 26, 2017 7:02 pm
Has thanked: 92 times
Been thanked: 338 times
A local stainless steel fabricators would sort that without any bother.
There's plenty around that specialise in stainless work, while many other fabricators will happily work in many materials including the stainless.
Where abouts are you out of interest...
PostPosted: Sun Feb 26, 2017 7:17 pm
Has thanked: 123 times
Been thanked: 133 times
Could you adapt a wine press? Something like this https://www.google.co.uk/imgres?imgurl= ... mrc&uact=8
Mike
PostPosted: Mon Feb 27, 2017 1:15 am
Hi someone-else,
Yes the piece I need is the silver part on the pict 2 and 3.
PostPosted: Mon Feb 27, 2017 1:18 am
Thank you kellys_eye I will have a look into your suggestions, this give me some other direction for my search.
PostPosted: Mon Feb 27, 2017 1:23 am
Thank you Hitch, I will try to contact some stainless steel fabricators around London UK where I am based.
PostPosted: Mon Feb 27, 2017 1:26 am
Hi London mike 61, this wine press looks good, I came across few while I was searching online but this one looks like it could be adapted to fit the purpose. I'll keep this as a plan B.
PostPosted: Mon Feb 27, 2017 2:25 pm
No problem mate , hope you find what you need
Mike
