It is currently Wed Sep 19, 2018 11:35 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
PostPosted: Thu Feb 16, 2017 11:38 pm
Has thanked: 9 times
Been thanked: 7 times
Hi guys.
I have some 18mm mdf that I want to put a small angled bevel on. The mdf will be on a wall and is large (150x185cm) and is visible so it needs to be accurate.
Is a router the only way to do this as I don't have one.
If so will I get away with the cheap screw fix one and which bit would be best
PostPosted: Thu Feb 16, 2017 11:44 pm
Has thanked: 400 times
Been thanked: 1445 times
A router is obviously quicker but a hand plane will do the job easily enough - either block or smoother.
PostPosted: Thu Feb 16, 2017 11:53 pm
How do I keep the plane straight as I will be planing the whole edge at 45 degrees
PostPosted: Fri Feb 17, 2017 12:11 am
Has thanked: 691 times
Been thanked: 1952 times
i would 100% say router iff you have a strait edge and accuracy is essential but that assumes the mdf is loose and can be layed overhanging an edge
what sort off chamfer you after ?? as in 9mm plain then the other half champhered or another percentage ??
PostPosted: Fri Feb 17, 2017 12:17 am
Small
Same as this
Image[/[URL=http://s87.photobucket.com/user/ashleywood_2006/media/Mobile%20Uploads/D6EB8B4D-9706-4ABF-BC78-328732C24F2B_zps28odclmx.jpg.html]Image
PostPosted: Fri Feb 17, 2017 12:18 am
Oh and yes I can lay it flat on my benches and clamp it down
PostPosted: Fri Feb 17, 2017 12:21 am
that looks like about 40mm material
go for a router/non slip mat from tool station for about £6 no clamping and easy moving :huray:
PostPosted: Fri Feb 17, 2017 12:34 am
Yeah that pic is 2 18mm glued together as that is the shelf the main bit is just 18mm (it's basically a large false wall to mount tv on and run wires behind with said shelf below for freebies box)
I have the mat so I'll get the router and try and work out the best bit
PostPosted: Fri Feb 17, 2017 12:44 am
if you have any 45% champher bit it will do mdf :huray:
all you need to do is set the plunge depth usually about 6mm more than you think to get the amount off champher you need
PostPosted: Fri Feb 17, 2017 12:53 am
Great thanks.
I'll get router this weekend. I have a load of bits. I actually have a router but it doesn't have the bracket part that keeps it straight so it's sort of like using a dremill so I'll get another as its a really old Bosch one
PostPosted: Fri Feb 17, 2017 7:14 am
Has thanked: 106 times
Been thanked: 455 times
You don't need a bracket to keep it straight, just use a chamfer bit with a bearing guide and run it around the edge
http://www.screwfix.com/p/erbauer-chamf ... -5mm/40946
Cheers,
Darren
PostPosted: Fri Feb 17, 2017 8:52 am
If you mean how you do maintain the angle of 45° - just practice, and a decent eye.
PostPosted: Fri Feb 17, 2017 12:34 pm
I'm not convinced I will have a steady enough hand, especially as I have never used a router before.
Anyway this is my router and I don't have many bits actually. And to top it off the bits don't fit the router :)
PostPosted: Fri Feb 17, 2017 12:35 pm
Now considering just sanding the edge as sanding I am good at :)
PostPosted: Fri Feb 17, 2017 12:41 pm
Has thanked: 1119 times
Been thanked: 1034 times
You can't really use that router like that. At least not for anything using a bearing guided cutter. There's no base with it.
looks like the base clamps around the part above the shaft, similar to the old B & D. Have you got the base? It should be like two parts, the collar part that clamps on, and the flat base with a hole in it. They're joined by round bars that allow the router to plunge.
ETA, If you want a proper, sharp edged chamfer sanding won't do it. You'll just have a "dubbed over" blurry edge. Up to you of course.
