It is currently Sat Jul 21, 2018 9:53 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
PostPosted: Mon Feb 13, 2017 11:40 pm
Has thanked: 1 times
Been thanked: 1 times
Hi, I'm going to be covering my existing timber window sills with PVC Fascia Boards https://www.toolstation.com/shop/p58910?table=no, my question is how do I cut the board to match the existing architrave?
Thanks!
PostPosted: Mon Feb 13, 2017 11:44 pm
Has thanked: 505 times
Been thanked: 97 times
NOW, that looks just like the task I'm going to have.
Please allow me to 'coat tail' you.
:hello2:
PostPosted: Mon Feb 13, 2017 11:53 pm
I just cant think how to get the outside corner neat, on door frames they under cut but last thing I want to do is mess the frame up!!
PostPosted: Tue Feb 14, 2017 12:07 am
All I can think of is a
Profile Contour Gauge.
https://en.wikipedia.org/wiki/Profile_gauge
Not that I've ever used one - yet!
PostPosted: Tue Feb 14, 2017 12:16 am
Yeah, that's what my dad has suggested, it's all the little details and curves I think it's going to struggle. I was thinking of making a plyboard template?
PostPosted: Tue Feb 14, 2017 12:17 am
Pro Tradesman
Has thanked: 202 times
Been thanked: 331 times
1st, that is dam expensive overboard :shock: try finding it at places like Eurocell or a building plastics company local to you, i pay less than half that cost for bigger boards.
2nd, that is dead easy to do without worrying about scribing anything. simply place a piece of board on top of your existing sill, use a multi-master and cut the architrave to allow the overboard to slide in. simple & neat.
id remove the trim from around the window though and put the overboard right up to the window frame.
For this message the author Rich-Ando has received thanks - 2: AAA.Handy.Man, alex_218b
PostPosted: Tue Feb 14, 2017 12:19 am
Jack Of All Trades
Has thanked: 205 times
Been thanked: 276 times
Make a profile with some thin card first, and then transfer it to the sill. So if you make any mistakes with the card you can do it time and time again till you get it perfected,
By eck! ©
PostPosted: Tue Feb 14, 2017 12:23 am
And I thought it was cheap! Cheers I'll have a shop around. I'm just a bit nervous of cutting the frame but it looks like that's. Going to be the cleanest way of doing it. Is this the same way as when laminate flooring is fitted under door frames?
PostPosted: Tue Feb 14, 2017 12:24 am
Pro Tradesman
exactly the same
PostPosted: Tue Feb 14, 2017 12:28 am
Cool, thanks. Got to say I've asked this on two other diy fourms and not had any answers. Thanks to you all.
PostPosted: Tue Feb 14, 2017 12:33 am
Pro Tradesman
also, if you are going to be doing the whole sill i would join the boards together with proper PVC glue such as
http://www.eurocell.co.uk/sealants-and-fixings/glues/silversil-s-glue-high-viscocity-50g-btl
http://www.eurocell.co.uk/sealants-and-fixings/glues/superglue-activator-200ml
http://www.eurocell.co.uk/trims-and-cills/window-boards - seems i must get a fair trade discount of these prices though. i would go instore, i bet you will get a better deal.
PostPosted: Tue Feb 14, 2017 12:36 am
Pro Tradesman
you know where to come straight to next time then :thumbright:
PostPosted: Tue Feb 14, 2017 12:37 am
Yeah they're bay windows and I've got three to do, I was going to use white sealant to try and hide the corner join a bit? I've. Assumed a no nails style glue would hold them in place ok?
PostPosted: Tue Feb 14, 2017 12:55 am
Pro Tradesman
the glue above is what we use in the trade. trying to join with silicone looks messy.
if you do not feel confident enough to cut your boards correctly 1st go, simply template your pieces priory to cutting the boards. i say this because although it may look easy, the required angles/straight edges vary to what people think they need to be and on novice 1st attempt they usually end up wrong. once you are happy, find grade sand the edges to be glued, spray activator on one board, glue on the other, hold together for 10 seconds (do it on a flat surface with a gap between so that the join is not in conact with anything). once done, you will have to snap the boards to part it.
yes you can use a polymer grip type adhesive to stick them down. probably best to rought he gloss finish up 1st though
PostPosted: Tue Feb 14, 2017 12:59 am
Amazing, thanks again. More info in an hour than in weeks of Googleing. I promise to do a follow up!!
Sent from my D5803 using Tapatalk
For this message the author alex_218b has received gratitude : Rich-Ando
