It is currently Wed May 23, 2018 9:47 am
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
 Post subject: AIRLESS SPRAYER
PostPosted: Tue Mar 06, 2012 7:38 pm
Has thanked: 16 times
Been thanked: 3 times
Hi All
Question - Has anyone ever used an airless sprayer - the industrial type that feed straight out the paint tin ??
are they anygood and what kind of finish do they produce ??
Can they be used in a house ??
I want to paint my house - inside - but it gets lots of lght so even the slightest DRY spot off a roller is showing up
Ive put 30 litres -yes 30 on the room and its like its just had one coat !! ::b
Ive even PVA the whole room in case it was sinking in through the plaster board
If I dont get it sorted soon Im going to have to buy smaller furniture as the room is getting smaller !!!
Any help advice gladly accepted :dunno:
 Post subject: Re: AIRLESS SPRAYER
PostPosted: Tue Mar 06, 2012 7:45 pm
Has thanked: 1421 times
Been thanked: 3659 times
johnnyuhtar wrote:
Ive even PVA'd the whole room in case it was sinking in through the plaster
::b ::b ::b to-use-pva-in-paint-or-not-that-is-the-question-t18116.html
Have fun with that thread....I would suggest lining the walls, then starting again....
With a Trade emulsion....
PostPosted: Tue Mar 06, 2012 7:46 pm
Has thanked: 309 times
Been thanked: 950 times
I'm guessing the paint chuckers are going to ask what make of paint you've been using?
30 litres :wtf:
PostPosted: Tue Mar 06, 2012 8:01 pm
Has thanked: 31 times
Been thanked: 197 times
30 litres with what (brush roller spray)?
O dear the old PVA thread again.
Give us a bit more info fella and see if we can get you out of the hole you're digging
Has thanked: 319 times
Been thanked: 573 times
Stop wasting money and hire a professional would be my advice
Interior Refurbishment Specialists | Brighton & Hove
PostPosted: Tue Mar 06, 2012 8:02 pm
Elephant Man
Has thanked: 584 times
Been thanked: 1332 times
Razor wrote:
paint chuckers
:lol: Paint Chuckers and Stickers. That should be on every van in the country.
30 litres (or 6 gallons by my reckoning) ........ That's a colossal amount of paint to have been used, or an enormous room. :shock: How many coats was that? And yes, what kind of paint have you been using?
If you've been using that Homebase Value or B&Q el cheapo gear, then that may explain why you've been tearing your hair out. The white from those ranges, covers hee-haw (as we say up here) and is basically a waste of money.
Have you PVA'd the whole room or just any patchy bits? (please don't say the whole room)
Nihil expectore in omnibus
PostPosted: Tue Mar 06, 2012 8:30 pm
Has thanked: 170 times
Been thanked: 240 times
If your using an industrial airless sprayer, it will spray heavy emulsions, contract emulsion easily. this would obliterate any surface. As a cost effective method on one house i wouldnt recommend this. I wouldnt recommend using airless spray unless your well competent....1, potential clean up disaster...2, Airless spray can be very dangerous if misused.
I would definitely change your paint...Dulux, crown etc and use a roller and a brush
PostPosted: Tue Mar 06, 2012 9:44 pm
Hi All
Im using LEYLAND SUPER LAYTEX EMULSION
Ive used it loads before when Ive plastered and normally covers great and NO problems
I had coated the room firstly with B&Q Trade paint for new plaster as there wes a lot of exposed drywall filler that I had to use to FIX the "PROFESSIONALS" mess that was meant to be a finished dry lining job (LAWSON & COWELL Dry lining contractors)
Im using a roller as usual and brush for cutting in
Just seem to keep getting DRY SPOTS like the paint has been stretched to far and when the light hits it it looks terrible
hence the full room PVA thinking it must be soaking in !!!!
Thats why I was thinking of the airless sprayer can cover a wall in no time and keep a wet edge /wall
have had experience paint spraying cars in the past so know its important when spraying to keep it wet
PostPosted: Tue Mar 06, 2012 9:59 pm
Stop, sand down the walls (not back to plaster but just a smooth uniform appearance) apply 2 coats of a quality flat Matt of vinyl Matt.
The problem you describe is 9/10 due to application error. Your walls now have a texture to them from the offending coat. And unless you want to apply another 6 coats it's not likely to disappear without sorting out the substrate.
A basic airless will set you back £500, a professional set up starts at £1000 really. But in anycase it will not solve your problem.
In addition but a decent roller
PostPosted: Tue Mar 06, 2012 10:40 pm
Ok colour republic
will do that tomorrow when its all dryed out
been using hamilton rollers / brushes but will get new sleeve tomorrow as well
Thanks for your time
PostPosted: Thu Mar 08, 2012 5:28 pm
COLOUR REPUBLIC - it didnt work its still patchy well more stripey now
back to the origional question has anyone used an AIRLESS SPRAYER to paint indoor house walls with emulsion?????????
All I want to know is what kind of finish does it produce ??????
Is it like a roller type texture or what ????
I dont care how much they are I just want the walls to be all the same texture and NO dry spots is this possible YES OR NO ??????
PostPosted: Thu Mar 08, 2012 6:26 pm
Has thanked: 8 times
Been thanked: 17 times
:director: Why don't people post good pictures of there problems makes it easier for us lot.
PostPosted: Thu Mar 08, 2012 6:29 pm
Answer to your question is yes, many times
It produces a smooth finish if done correctly.....it produces a terrible finish if not....you say youve done automotive...then you will not have a problem...just move faster
Is this the answer?....in my opinion no....you should be able to sort this out with brush and roller
It may be worth buying a Purdy roller sleeve 9" colossus and decent brush..as it sounds like your application is the problem, stir the paint, dont over roll...about 1 meter square per dip, cut in first then roll
Airless spray is primarily an application method for speed.
PostPosted: Thu Mar 08, 2012 6:53 pm
Has thanked: 5 times
Been thanked: 12 times
johnny boy! what brand of paint are you using? I once had this problem using a dark brown in a standard bnq dulux emulsion, changed to johstone cova plus vynl matt....no problems...
PostPosted: Thu Mar 08, 2012 7:24 pm
K Decor
Im using Leyland super laytex
I always use it and find it great it is patchy when first applied especially magnolia its dark and patchy but when dry is about 2 shades lighter and flawless
I had a problem with a newly plastered chimney bast one time (oatmeal colour) you could see the plaster corner beads through the paint - they were well covered in plaster went on great when it dried could see the holes and lines like morse code up the wall - it spelt out - IM GOING TO KEEP COMING THROUGH SUCKER !!!
had to PVA it 3 times then it covered took 5 litres though !!!!!!
Think its coming back to get me !!!!!!!! :lol:
Users browsing this forum: dynamod and 1 guest
