Page 1 of 1
[ 5 posts ] |
| Author |
Message |
Stoday
Posted: Tue Sep 07, 2010 2:35 am |
| Deceased 21-10-2011 R.I.P |
Joined: Fri Jan 20, 2006 6:03 pm Posts: 5956 Location: East of England Has thanked: 9 times Been thanked: 93 times
Has anyone used the resin capsule stud fixing method? Where you stick a resin capsule in the hole and hammer your stud in, breaking the glass and mixing the resin?
How good is it? Seems just the job for someone who only has 1 or 2 holes a year because the capsule keeps the resin unmixed.
_________________ I should be dead; I've cheated the Grim Reaper yet again by surviving my third heart attack in June.
| Top |
Steve the Gas
Posted: Tue Sep 07, 2010 6:14 am |
| Senior Member |
Joined: Fri May 30, 2008 7:50 am Posts: 3306 Location: Notts/Derbys Has thanked: 0 times Been thanked: 32 times
They are great and actually work well if you install them correctly- NOT with a hammer. They are supposed to be driven in by rotary hammer action to adequately mix the stuff inc the glass up and this type should NOT be used in brick.
_________________ Sciatica is a pain in the Ar5e ............ and leg
| Top |
register or
log in
StyXSIS
Posted: Tue Sep 07, 2010 12:42 pm |
| Senior Member |
Joined: Tue May 04, 2010 1:49 pm Posts: 772 Location: Manchester Has thanked: 32 times Been thanked: 79 times
Hi Stoday i fully agree with Steve the Gas they are good and realy easy to use, heres some info on how to use them its page 3 if i remember right
For this message the author StyXSIS has received gratitude : Stoday |
| Top |
register or
log in
Stoday
Posted: Tue Sep 07, 2010 5:31 pm |
Thanks Steve & Styx.
Someone must have found the link useful; I'm here in less than 5 hours after Styx posted and it's been downloaded 7 times already.
| Top |
register or
log in
Hitch
Posted: Tue Sep 07, 2010 11:26 pm |
| Senior Member |
Joined: Mon Jan 16, 2006 8:16 pm Posts: 4537 Location: Somerset Has thanked: 5 times Been thanked: 86 times
Yes, tend to use the injection system much more though. As said the capsules go in and are driven by drill with adaptor, if you buy the propper studs, they have a hex on/in the top.
Otherwise, a few knocks with a hammer, but make sure you give it a good few turns to get it all mixed up.
Remember to observe the hole size required for the stud, 2mm bigger upto m16, then M20 up is +4mm
_________________ Why isn't the number 11 pronounced onety one?
| Top |
register or
log in
Page 1 of 1
[ 5 posts ] |
