It is currently Wed Feb 08, 2012 11:27 am
 Post subject: UPVC Broken seal?
PostPosted: Tue Aug 31, 2010 4:17 pm
Has thanked: 13 times
Been thanked: 2 times
I have a couple of windows with condensation inside the glass so it looks like a broken seal.
This may be a daft question but does it cause heat loss at all?
Many Thanks
 Post subject: Re: UPVC Broken seal?
PostPosted: Tue Aug 31, 2010 4:30 pm
OAP
Has thanked: 180 times
Been thanked: 1978 times
Yes, because it is now only secondary glazing, check the Guarantee.
For this message the author thescruff has received gratitude : mhands
PostPosted: Tue Aug 31, 2010 8:20 pm
Thanks.
I cannot check guarantee as windows were fitted by the past owners.
Is there much of a loss?
PostPosted: Tue Aug 31, 2010 10:26 pm
OAP
Guessing, I would say quite a bit, because they work by having a vacuum between the glass.
PostPosted: Thu Sep 02, 2010 8:10 pm
Has thanked: 1 times
Been thanked: 6 times
The loss is probably quite low.
Normal units do not have a vacuum they are just sealed. The air is trapped and so there is minimum movement and therefore minimum heat transfer.
Regards secondary double glazing, this is normally a better insulator as the distance between the glass units effects the performance. So a 28mm units is better than a 20mm unit - therefore secondary with a 150mm gap is better still - also better for noise reduction. The seals need to good though.
If you ask enough people, one will have the answer!
