It is currently Thu Feb 09, 2012 5:25 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: Lining - Chimney Breast
PostPosted: Fri Aug 27, 2010 8:47 am
Has thanked: 43 times
Been thanked: 11 times
Line up to or around external corners?? I'm going to paint it. Fancy the latter.
Decisions decisions!!! :lol:
PostPosted: Fri Aug 27, 2010 10:06 am
Has thanked: 2 times
Been thanked: 44 times
Same here I'd line around both internal and external.
John
PostPosted: Fri Aug 27, 2010 10:22 am
John
That's interesting. I usually line to the corners then caulk. I'd be worried about the walls being out and having to splice every time.
Benj
EDIT: Realised that because i'll be cross lining i'll have to stop at internals, otherwise i'd need a hell of a piece to circle the whole room!!!! :lol:
PostPosted: Fri Aug 27, 2010 10:47 am
It's ages since I lined a whole room, I used to line into corners tear the paper about an 1" past, then start again as level as possible.
I am going back 30 years or more, when we had to cut a strip off one or both sides of wallpaper.
John
PostPosted: Fri Aug 27, 2010 9:29 pm
Has thanked: 54 times
Been thanked: 86 times
Thats more or less what I do with LP, but with the external corners, specially if they are out.
I paper up to the external corner, then tear all the way down just on the corner, so you have that tear/ragged effect all the way down, then when dry, sand the torn edge, and then feather the edge with filler, when dry, gently sand, then paint, now you have a lovely sharp corner edge :-)
I would rather want something I dont have, that have something I dont want
PostPosted: Sun Aug 29, 2010 9:34 pm
instead of drop lining it just cross line it much easier to do, always line to a internal corner and caulk. i always prefer to cross line, i think it makes a better job and much quicker
PostPosted: Mon Aug 30, 2010 7:58 pm
I think krispy was asking about external corners, most decs caulk the internal corners, sometimes I do, sometimes I dont, depends what mood I am in. :wink:
