| Author |
Message |
Modders
Posted: Sat Aug 07, 2010 6:54 pm |
| Newly registered Member |
Joined: Sat Aug 07, 2010 6:41 pm Posts: 7 Has thanked: 11 times Been thanked: 0 times
Hi All,
My sister has had her spare room skimmed and asked me to paint it. I gave the plaster 2 coats of cheap B&Q emulsion (watered down) and then applied 2 coats of Dulux Light & Space Paint the next day.
The first 2 coats of B&Q emulsion seemed to take forever to dry but the Dulux was dry to the touch within 30 minutes.
I went back today to give it another coat, only to find the first had cracked like mud. I’ve applied another coat but watered it down a little this time to see if it would cover the cracks.
My sis has just phoned to say it has dried the same as the first, can anybody tell me what I’ve done wrong and how to fix it? Is there a paint that I can use to fill the cracks, or will I have to remove the cracked paint first?
| Top |
wine~o
Posted: Sat Aug 07, 2010 8:27 pm |
| Senior Member |
Joined: Sat Jan 10, 2009 3:49 pm Posts: 6646 Location: hants/dorset border Has thanked: 150 times Been thanked: 507 times
Did you use Vinyl emulsion on the first two coats? (Mist coats )
_________________ . If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : http://www.donnasdreamhouse.co.uk/__________________________________ __________________________________ Verwood HandymanI Know it says I'm On-line, but I might have just left myself logged in, whilst I'm out....
For this message the author wine~o has received gratitude : Modders |
| Top |
register or
log in
Modders
Posted: Sat Aug 07, 2010 9:34 pm |
Hi wine~o, thanks for the reply.
I have just checked with sis to see what the paint was, and it’s silk! I could kick myself for not checking what they’d bought.
Ok, does this mean I’ll have to scrape it down to the plaster?
| Top |
register or
log in
wine~o
Posted: Sat Aug 07, 2010 9:38 pm |
| Senior Member |
Prolly... sand it back..get some Non-vinyl bog standard (Some will say trade) NOT B&Q matt emulsionAnd start again....sorry..
| Top |
register or
log in
fordy
Posted: Sat Aug 07, 2010 11:24 pm |
| Senior Member |
Joined: Mon Jan 21, 2008 9:21 pm Posts: 2226 Has thanked: 10 times Been thanked: 133 times
Youve made the mistake now so its a case of do the best with what youve got. You may have problems later but remedy what you have to work with now. Id personally undercoat the whole room as this will seal the cracking and give you a decent base to work off. If you can sand back 4 coats of paint, good luck to ya.
For this message the author fordy has received gratitude : Modders |
| Top |
register or
log in
wine~o
Posted: Sat Aug 07, 2010 11:28 pm |
| Senior Member |
 the pro's are back from the pub...
| Top |
register or
log in
fordy
Posted: Sat Aug 07, 2010 11:34 pm |
| Senior Member |
Just had visions of some poor fooker sanding down walls for 2 3 days
| Top |
register or
log in
Modders
Posted: Sun Aug 08, 2010 12:07 am |
Thanks for the input guys. I feel like a right tool for making such a stupid mistake, but what’s done is done.
My sis has spent 50k + on IVF treatment and it really means a lot to her having the nursery done correctly, so I need to get it sorted. I’m working 2 jobs at the moment so, as you can imagine, spending days sanding isn’t very appealing but if needed I will.
Would the undercoat cover the cracks? And can you recommend one? The dulux light and space doesn’t look any better than other matt paints, so I don’t think I’ll be using that again.
Thanks again for your help.
| Top |
register or
log in
fordy
Posted: Sun Aug 08, 2010 9:59 am |
| Senior Member |
Yes it will sort cracks out. Id go with dulux diamond matt on top to give a bit more added protection on the walls. When the babba is crawling and using crayons on the walls it will be easier to clean off, if you feel that a bit excessive just go for a dulux vinyl matt. The light and space stuff IMO is a bit gimmicky and plays on the uneducated DIYer
| Top |
register or
log in
brushmate
Posted: Sun Aug 08, 2010 11:18 am |
| Senior Member |
Joined: Tue Jan 08, 2008 8:41 pm Posts: 395 Location: Colne Lancs Has thanked: 1 times Been thanked: 2 times
Modders if you still have problems, as a last resort you could hang a lining paper and then paint.
_________________ Dont let what you can not do, interfere with what you can do.
| Top |
register or
log in
Modders
Posted: Sun Aug 08, 2010 12:05 pm |
So I need a dulux undercoat and then repaint with dulux diamond matt, or does the diamond matt not need an undercoat?
Thanks brushmate, I’ll keep that in mind.
| Top |
register or
log in
Puma
Posted: Sun Aug 08, 2010 2:10 pm |
| Senior Member |
Joined: Fri Mar 05, 2010 8:40 pm Posts: 1519 Location: Bristol Has thanked: 53 times Been thanked: 174 times
An undercoat is a good idea, but test the paint - has it stuck well or is it flaking off easily? If it is flaking off use undercoat. The main thing now is to use a thick paint and this should fill the hairline cracks - the Diamond matt is a good suggestion - all the main brands do similar products which are prob a bit cheaper. You'll have to fill, if the cracks are too wide to disappear with just the paint.
For this message the author Puma has received gratitude : Modders |
| Top |
register or
log in
Modders
Posted: Sun Aug 08, 2010 2:57 pm |
Cheers Puma.
The paint isn’t flaking, I lightly sanded an area yesterday and it seems to have a good grip. The worst parts are the corners where it has been brushed on, so I may have to fill these.
I think I’ll try a small area with the diamond matt, should it be watered down a little or put on straight from the tin?
| Top |
register or
log in
Puma
Posted: Sun Aug 08, 2010 4:47 pm |
| Senior Member |
If it won't pour out of the can water it down 5% IMO
| Top |
register or
log in
Modders
Posted: Tue Aug 10, 2010 4:41 pm |
Thanks Puma. I've had to order the paint, my local B&Q didn't have it. They had one called Dulux Performance, which i thought may have been the retail version, but they didn't have the right colour.
| Top |
register or
log in
