It is currently Thu Feb 09, 2012 5:35 am
PostPosted: Thu Aug 05, 2010 9:02 am
Has thanked: 1 times
I have to wire an electric central heating system. It's a 6 KW electric heater with a cylinder stat, pump, room stat, programmer and 2 motorised valves. Does anyone have a wiring diagram for this, at the moment I only know it's Danfoss motorised valves.
On the heater it is rated for 32A and 6KW, but only between 6M away from the consumer unit, therefore a 6mm Tw/E or 2.5mm Tw/E ?? and will this need to isolated at source with a 40A DP switch and at the consumer unit with a 40A CB or is a 32A CB still OK.
PostPosted: Thu Aug 05, 2010 12:49 pm
OAP
Has thanked: 181 times
Been thanked: 1980 times
The system components will be wired as a normal S plan, and there must be something in the heater that responds to a call or close signal.
For this message the author thescruff has received gratitude : gordon1962
PostPosted: Thu Aug 05, 2010 2:07 pm
Thanks, have just found the instruction manual on the web
