Page 1 of 1
[ 2 posts ] |
| Author |
Message |
glasgaeboy
Posted: Sun Jul 25, 2010 10:46 am |
| Newly registered Member |
Joined: Sun Jul 25, 2010 10:33 am Posts: 1 Has thanked: 1 times Been thanked: 0 times
I live in a 1950s detached 3 bed wimpey house, there is a chimney breast in the living room, on the first floor it passes through and is visible on the external wall, I assume this is to save on internal space upstairs as there is no chimney breast visible in the upstairs bedroom. If I was to remove the downstairs chimney breast would the remainder of the breast upstairs have to be supported-I am not convinced this is load bearing as surely it is supported by the external wall as it is attached to. I rewired the house last year and from memory the joists run parallel with the breast. I will have to extend and join the joists either side of the chimney breast upstairs and for the hearth downstairs, has any one come accross this? Thanks in advance.
| Top |
Simon Site Manager
Posted: Sun Jul 25, 2010 10:48 am |
| Senior Member |
Joined: Tue Oct 27, 2009 8:55 pm Posts: 3074 Location: St Helens Merseyside Has thanked: 33 times Been thanked: 174 times
Hi Mate,
Get a Structural Engineer to check out before you start removing. If anything goes wrong, he will be covered by Professional Idemnity Insurance.
S
_________________ Measure twice, cut once!
| Top |
register or
log in
Page 1 of 1
[ 2 posts ] |
