It is currently Thu Feb 09, 2012 5:54 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: Wiring the garage
PostPosted: Sun Jun 20, 2010 9:11 am
I have recently moved, and when I looked at the wiring in the garage it was a disaster waiting to happen.There was bell wire to sockets and generally a big mess of wires.
I am an aircraft electrician by trade but dont know much about house wiring.I have spoke to a local electrician who is happy to, connect it to the consumer unit it the house, and commision it for me once the install is complete.
I am going to be installing:-
3x double sockets (radial using 2.5mm, 30amp CB)
2x58w light tubes(1.5mm 6amp CB)
3x Outside lights(indivitually switched 1.5mm 6amp CB)
1xOutoor IP66 socket
1x 16amp socket(running a 3hp compressor)
The questions I have are:-
1. If I use a 5way consumer unit is it best to split the as above and protect all but the lights with an RCD breaker?
2. If so what size RCD should I get?
3. What cable size and CB size will I need to run to the 16amp socket?
4. What size cable should I run from the house consumer unit to garage?Garage is on other side of wall from house consumer unit so only needs a hole in the wall.
5. What size CB to outside socket?
Thanks in advance for the help
Jon
 Post subject: Re: Wiring the garage
PostPosted: Sun Jun 20, 2010 12:24 pm
Has thanked: 9 times
Been thanked: 75 times
32A MCB is too big for 2.5 radial so upgrade to 4mm or use 20A MCB
OK
OK
16/20A MCB 2.5mm cable or run it with the inside sockets
16A MCB may have to be a type C 1.5mm or 2.5mm
Fine
30mA trip, 40A or higher rating
6mm on a 40A
Jon
