It is currently Wed Feb 08, 2012 6:21 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
PostPosted: Tue Jun 15, 2010 2:47 pm
Hi
in desperate need of help?
I've just replaced my old toilet syphon with a new "Derwent Metro three part oblong syphon 10" and very thing seemed fine until the toilet was filled, and then every 5 to 10 minutes a drop of water leaks from the joint securing the syphon to the actual toilet?
Is there any bonding material that I could use to stop this very slow leak, but all the same annoying?
As you will guess from this - I'm new to any DIY.
Many Thanks
PostPosted: Tue Jun 15, 2010 3:06 pm
OAP
Has thanked: 180 times
Been thanked: 1978 times
There should be a rubber washer inside the cistern.
PostPosted: Tue Jun 15, 2010 3:09 pm
Many thanks thescruff, however there is a large black rubber washer on the inside of the cistern - its came with the syphon?
PostPosted: Tue Jun 15, 2010 3:30 pm
OAP
If you cleaned the inside it shouldn't leak in that case.
Are you sure thats where it's coming from.
PostPosted: Tue Jun 15, 2010 3:51 pm
Hi thescruff
yes it's seeping very very slowly from the joint between the bottom of the toilet and the securing plastic nut(for the better use of a word)?
I'll try cleaning the inside of the cistern were the black rubber washer contects to the syphon.
Many thanks for your help?
-- Tue Jun 15, 2010 4:01 pm --
Hi thescruff again - I've now just check our other toilet which has the same syphon and that has a washer on the outside as well as the inside? Maybe I need to get a washer for the outside?
Regards
Nigel P Richardson
PostPosted: Tue Jun 15, 2010 4:04 pm
OAP
No, just the inside seals it.
PostPosted: Wed Jun 16, 2010 10:41 pm
Has thanked: 7 times
Been thanked: 17 times
Had the same problem when changing a syphon recently (leaking round the base) discovered that the new washer was slightly thinner and harder than the old one so, as the old washer was still in good condition I re used it - Problem solved.
Trevor
Users browsing this forum: darrenba and 3 guests
