It is currently Wed Feb 08, 2012 6:05 pm
 Post subject: handle height
PostPosted: Thu Apr 08, 2010 6:30 pm
Has thanked: 12 times
Been thanked: 122 times
hi all
just been doing a extension to a house,
fitted the door to the new bathroom and made the spindle height 1000mm
i was always taught 1000 and all the other doors in the house are 1000,
the existing doors are flush vaneered and the new door is a 4 panel egg box, the mid rail is set at 900 and the cust has complained that the handle not in the rail,
were do you guys put the spindle height?
 Post subject:
PostPosted: Thu Apr 08, 2010 8:30 pm
Has thanked: 109 times
Been thanked: 405 times
you should never mortice a lock into any join in the door as it weekens the door
surface mounted locks yes as they dont weaken the door
if they want anything else its there responcibility as you have fitted the lock in the time served "normal "position
 Post subject:
PostPosted: Thu Apr 08, 2010 10:22 pm
Has thanked: 18 times
Been thanked: 60 times
Its the customers house so should explain beforehand where you want to put it and why.If they want it in the wrong place so be it, its their door and their house, as long as you put it in writing you wont be responsible for the door falling apart afterwards.My invoices have a box for adding comments and they sign underneath that they have read the comments box above.All nice and clear for all involved this way.
 Post subject:
PostPosted: Thu Apr 08, 2010 10:33 pm
Jack Of All Trades
Has thanked: 22 times
Been thanked: 45 times
If it's 'egg box', then 900mm would probably miss the 'lock block' thats built in.
By eck!
 Post subject:
PostPosted: Fri Apr 09, 2010 12:36 am
Been thanked: 57 times
thats normal for egg box door. in the mid rail is far too low. i always set spindle height at 1000
 Post subject:
PostPosted: Wed Apr 14, 2010 8:26 pm
Member
Has thanked: 1 times
Been thanked: 4 times
I do them at 1-0m to the 'pin' unless the other doors that are located nearby are different I do them to match....
One thing you should never forget is to never put a mortise lock in a door where a joint is located as it will weaken the door
