It is currently Thu Feb 09, 2012 4:36 am
 Post subject: basement wall insulation
PostPosted: Fri Mar 12, 2010 6:48 pm
hi there,
I am planning to put up framed insulation on existing basement walls as follows:
oldroyd damp membrane
studwork with insulation between battens
plasterboard
plaster skim
the question is how deep should the battens be and how deep should the insulation be? Also what type of insulation is best for this application?
Any ideas appreciated.
 Post subject:
PostPosted: Fri Mar 12, 2010 7:08 pm
Has thanked: 2 times
Been thanked: 320 times
Don't use battens....Gypline it. A lot quicker and a lot easier to do.
 Post subject:
PostPosted: Fri Mar 12, 2010 8:30 pm
I'll check out the gypliner system, can you add insulation behind it?
I have access to discounted timber, so battens seem a good bet for the moment.
 Post subject:
PostPosted: Fri Mar 12, 2010 9:31 pm
Has thanked: 42 times
Been thanked: 239 times
Do not gypline it but build a 70mm stud wall using gypframe (or richter which is cheaper) against the existing wall and secure it to floor and ceiling being careful not to pierce the damp proofing in the floor or wall and gap filling foam half way between the two. then fit 50mm kingspan or celotex between the studs and plasterboard over the top.
Alternatively bond insulating plasterboard to the wall using bonding compound and skim.
Try british gypsum's website and look at minsters or sheffins who actually supply these products direct.
 Post subject:
PostPosted: Fri Mar 12, 2010 10:37 pm
Gypliner needs to have brackets securing it to wall which takes the flex out of it. As you were screwing batten to walls this is why it was suggested.
As Jozeffo has pointed out best way to do it without actually having to put a fixing through the membrane is to use stud and track.
 Post subject:
PostPosted: Sun Mar 14, 2010 12:16 am
Thanks for the advice.
I am considering using resilient bars to aid soundproofing on this wall.
As these decouple the boarding so that it can flex I am wondering whether it would cause cracks in the skim coat where the wall joins the ceiling?
