It is currently Sun May 27, 2018 1:03 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 18 posts ]  Go to page 1, 2  Next
PostPosted: Thu Feb 25, 2010 7:53 pm
Has thanked: 1 times
The electric is there and the thermostat is triggering the boiler which seems as if its trying to start up but in the window all i can see is a blue spark which keeps sparking but no flame - help please
Thanks in advance
 Post subject:
PostPosted: Thu Feb 25, 2010 11:08 pm
Been thanked: 12 times
The pilot solenoids on these were a common fault. Either that or a blocked pilot.
The fault is probably best left to an RGI to sort out for safety reasons, sorry.
Richard
 Post subject:
PostPosted: Thu Feb 25, 2010 11:20 pm
ok thanks rio. I wasnt gonna attempt fix myself, but had a bad experience with a plumber who told me i would need a new power shower when the fault was actually the brushes in the motor!! so just wanted to try and get myself a bit of info first
any idea on cost of this type of repair - ball park
thinking of going for bg's fixed price repair which is £168, any thoughts on that
 Post subject:
PostPosted: Sat Feb 27, 2010 6:17 am
About £80 to service it and clear a blocked pilot is about right in my area.
If it is the solenoid, possibly the complete gas valve i would go for the fixed price repair.
The gas is defo turned on isnt it :roll:
Richard
 Post subject:
PostPosted: Mon Mar 08, 2010 11:51 am
Gas/Heating Expert
Has thanked: 27 times
Been thanked: 295 times
So we may never know what was the problem or how he got it fixed.
Does British Gas still do fixed price repairs on these?
Tony
 Post subject:
PostPosted: Mon Mar 08, 2010 2:31 pm
Has thanked: 311 times
Been thanked: 950 times
Who seriously thinks a bg engineer would actually bother to get the tools out for one of these???
 Post subject:
PostPosted: Tue Mar 09, 2010 10:38 am
Gas/Heating Expert
I asked a BG yesterday and he said they still go and repair them!
Tony
 Post subject:
PostPosted: Tue Mar 16, 2010 6:42 pm
I would gladly reapir a Netaheat. I have the Gas valves (for the MKII and the Electronic), fans, earthing brackets, PCB's and the odd Heat Ex kicking about in my lock-up. I still service about 10 of them every year, and replace the heat ex gaskets when required.
Skip.
 Post subject:
PostPosted: Wed Mar 17, 2010 9:21 am
Gas/Heating Expert
Perhaps you are semi retired or very short of work!
To service them PROPERLY is a very time consuming task and in many cases comes up with a corroded case or failed case seals and the job cannot be completed ( or often charged for ).
In fact I tell people that if its working properly then its best left untouched and the service price put towards a replacement within the next year or two.
The problem is if you service such an old boiler then there is always a big chance that something will fail shortly afterwards and YOU will be blamed just because you serviced it.
When saying that I am primarily thinking of the mercury switch variant where the spare part is not generally available although we do have a new one for any of our customers.
Tony
 Post subject:
PostPosted: Wed Mar 17, 2010 7:28 pm
Tony
Tony,
The Mercury Vapour Valve was on the Mark I.
I have serviced them for years and never had a problem. I generally put a smoke bomb in the 'Outer Flue' when the boiler is operating. I also run a CO detector around the case once serviced to ensure no 'spillage' from the case seal. Ive seen a few that have burnt through on base of the boiler (in the area of the pilot / earthing bracket assy). - ID and replace boiler.
Case seals repairs are far more common on the Ideal WRS IMO.
And no, Im not near retirement or desperate for work.... I just look after my customers boilers. I spend 2 hours on a Netaheat, and will continue to do so.
I fail so see how an old boiler should not be serviced. I have a car built in the 1970's that is still serviced / repaired.
Skip.
 Post subject:
PostPosted: Wed Mar 17, 2010 9:34 pm
Fair play to you Skip and :welcome:
As long as you condemn all those old servowarms........
Like the Scruffs :lol: :lol:
 Post subject:
PostPosted: Wed Mar 17, 2010 9:38 pm
Has thanked: 422 times
Been thanked: 3903 times
The Elite 50e, one of the best boilers ever made. :lol: :thumbright:
 Post subject:
PostPosted: Thu Mar 18, 2010 12:14 am
Gas/Heating Expert
I went to repair a Servowarm a couple of weeks ago.
It had a radiator at the front instead of a case!
It also had a flint for lighting the pilot light!
 Post subject:
PostPosted: Thu Mar 18, 2010 12:52 am
Hope you changed the O rings on the nipples :roll:
 Post subject:
PostPosted: Thu Mar 18, 2010 1:00 am
Gas/Heating Expert
I have been told off before for touching nipples so I left them alone. Also been advised the "O" rings are no longer available and so I did not attempt to move the rad at all.
Of course I did change the flint in the lighter.
Oddly there was an o/h stat tied near the top with a piece of wire.
That may have been added as an afterthought although the boiler is on an open vent system and probably not suitable for a sealed system.
Does anyone know why that was there and where it should have been fitted if it was a makers idea?
Tony
