Page 1 of 1
[ 8 posts ] |
| Author |
Message |
fixer
Posted: Mon Feb 15, 2010 11:25 am |
| Newly registered Member |
Joined: Tue Feb 09, 2010 12:28 pm Posts: 10 Has thanked: 0 times Been thanked: 0 times
I'm looking to replace my old hammer drill that finally gave up the ghost this weekend. I am currently installing a bathroom and need a drill that can go through tiles without shattering them. I am a bit confused by the SDS plus drills (i.e. Ryobi ERH-750V 240V 3kg SDS Plus Hammer Drill from screw fix) as I have an SDS drill and the hammer action is so strong it shatters tiles. As the bathroom is all tiled and grouted I don't want to even try using this.
Would something like a Ryobi ERH-750V 240V 3kg SDS Plus Hammer Drill be ok or should I look for something else??
| Top |
thescruff
Posted: Mon Feb 15, 2010 11:41 am |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39106 Has thanked: 180 times Been thanked: 1978 times
You should be able to take the hammer action off, fit and sds chuck, then any good tile drill, I like the arrow drill bits for tiles, there ain't much they won't drill, or go for a diamond drill.
_________________ --------------------------------------------------------------------------------------------------- If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
speed
Posted: Mon Feb 15, 2010 5:59 pm |
| Senior Member |
Joined: Thu Jan 01, 2009 8:26 pm Posts: 1505 Location: barnsley Has thanked: 12 times Been thanked: 122 times
i like using the bosch multi construction bits, i use 1mm oversize to the plug drillbit in cordless driver
then can drill with hammer drill slowly in backing material
| Top |
register or
log in
register or
log in
DIY_Johnny
Posted: Mon Feb 15, 2010 6:10 pm |
| Mr. Grumpy |
Joined: Tue Nov 18, 2008 3:41 pm Posts: 2415 Has thanked: 0 times Been thanked: 32 times
if you are drilling through tiles, I would certainly take hammer action off. Those drill bits speed noted are good but I have never had a problem with ordinary masonary bits on ceramic. I give it a squirt of water and let the drill bit crunch away on slow speed but if I have the multi construction ones to hand, all the better. The sharper angle head is quicker
| Top |
register or
log in
fixer
Posted: Tue Feb 16, 2010 11:58 am |
Thanks guys for the great advice. I'll let you know how it goes
_________________ John
| Top |
register or
log in
lockie
Posted: Tue Feb 16, 2010 8:12 pm |
| Senior Member |
Joined: Mon Jun 16, 2008 10:42 pm Posts: 1250 Location: dan sarf Has thanked: 18 times Been thanked: 60 times
Put a bit of masking tape on the tile first to help it stop slipping as you start the hole.I like the bosch multiconstruction too.Use them for metal as well as masonery.
| Top |
register or
log in
fixer
Posted: Tue Apr 20, 2010 11:24 am |
Just a note to thank you all for your help here. I wasn't able to get the multiconstruction bits but I did use some tile bits and the hammer action off. Worked like a dream
| Top |
register or
log in
Page 1 of 1
[ 8 posts ] |
