It is currently Wed Feb 08, 2012 6:45 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 21 posts ]  Go to page 1, 2  Next
PostPosted: Tue Dec 08, 2009 7:11 pm
General Builder
Been thanked: 5 times
ok, we have a shower unit.
The shower head was put in the tray and left to run - NO LEAK.
The sealant has all been re-done.
There is still a leak coming from beneath the tray in the corner when the shower is run over the left cheek of tiling (as you look at it from the outside), but not over the right.
It's not possible that the shower tap fixing is leaking right? It's re-sealed with silicone, so I mean through the actual fitting. If not then the only remaining option is the grouting, which I think must be the problem, but it looks good.
I suppose my question is, 'can failed grouting look ok?'.
pics -
File comment: wider / better view of grouting.
File comment: pic of grouting. It looks gariny in the pic, but I can assure you that's because it's all wet, it's the same grans as you can see on the tiles, the grouting looks good.
File comment: Internal corner, again, seal is new/good
File comment: Internal view of the corner that is showing damp from outside. The silicone at the bottom is new/good. Also the seal up the screen is good, but there is no damp above floor level outside anyway.
File comment: These are the tap fittings, as you can see, the silicone seal is new/good. The grouting also looks ok.
File comment: This is an overview of the shower. The damp comes through in the corner where the carpet is liften. The damp is coming through beneath the tray.
 Post subject:
PostPosted: Tue Dec 08, 2009 9:24 pm
Has thanked: 5 times
Been thanked: 86 times
Dont forget grouting isnt waterproof...wouldnt have though a quick lick with the shower would soak it that easily though...
Water in the door track, running along, and out at the end/outside?
 Post subject:
PostPosted: Tue Dec 08, 2009 9:49 pm
Has thanked: 109 times
Been thanked: 405 times
yep i am with hitch on this one could also be the uprights off the framework as they are hollow
 Post subject:
PostPosted: Wed Dec 09, 2009 12:06 am
Been thanked: 47 times
i know you said you replaced the silicone but did you check the tray for movement before it was resealed? floor looks to be timber and in my experiance 90% of leaky trays i due to the tray moving while somone is in the shower allowing the water to escape!
IF IT WERE EASY ITD B BORING!
 Post subject:
PostPosted: Wed Dec 09, 2009 1:35 am
Has thanked: 3 times
Been thanked: 6 times
Don't trust the door. Check it carefully, you may want to aim the shower directly at the seals and try to force any water leaks...see if that shows up as more damp or a clear leak? :hello2:
Our leaky shower isn't really 'leaky' its just a crap door that allows water to exit when water is directed straight at the bottom so that its forced out. :sad:
IF you want to test the shower fixing/s, you could try removing the shower head and run the hose directly to the waste so that you're not getting any water in the cubicle. That way any fixing leaks should showup as more damp, becuase they won't be caused by water splashed on the tiles.
Don't buy a dwarf with learning difficulties,
It's not big and it's not clever.
 Post subject:
PostPosted: Wed Dec 09, 2009 7:30 am
General Builder
umpossible imo.
The water is coning through from beneath the tray.
I can see it almost immediately when the shower is run, but the side of the tray (where it meets the skirting board) is bone dry, as is the skirting board, and the area where the screen meets the tray, the length of the shower.
 Post subject:
PostPosted: Wed Dec 09, 2009 7:35 am
General Builder
Well I didn't replace the silicone, the client did. I'll post a picture of the job he did.
You'll lol.
Basically the seal between the tiles and tray look like someone's tried to form the walls of jericho with white sealant.
also, the leak is there when the tray is unoccupied.
This pic is idicative of the levels of sealant currently breaching anywhere that there could be a leak in the sealant.
 Post subject:
PostPosted: Wed Dec 09, 2009 7:36 am
General Builder
we've run the shower directly into the tray. No damp.
 Post subject:
PostPosted: Wed Dec 09, 2009 7:54 am
Been thanked: 29 times
Hi Python,
Are you able to access and take a look at the trap?
I would basically try and eliminate things by firstly just running water into the tray, then if thats fine run water against the affected side panel first at low level then work up until the leak is found?
 Post subject:
PostPosted: Wed Dec 09, 2009 10:01 am
Has thanked: 16 times
Been thanked: 217 times
I would say that it is a good chance it is the tray movement. The screen frame to tray joint has probably got a hole in it letting the water find a way out in that corner. The problem with movement like this is that the sealant is stretched and gives way and it only needs to be a tiny opening to let water through.
Try some kitchen roll on the side of the tray in that corner to establish if the water is running down the side of the outside tray. It could of course be going do the back edge of the tray in the same way although this will be harder to spot.
 Post subject:
PostPosted: Wed Dec 09, 2009 11:03 am
Has thanked: 42 times
Been thanked: 239 times
Tray movement or trap would be the obvious suspects.
 Post subject:
PostPosted: Wed Dec 09, 2009 11:47 am
iff the leak appears in the corner heres the senario i had
water was hitting the screen
found its way between 2 very tight surfaces into the expansion gap
water reaches the base and leaks out so you seal the outside water still comes so you seal the inside water now only has a path under the frame to the side till it hits the wall
solution seal the full height top to 12mm from the tray
what we tend to forget is a shower can be well sealed but introduce a body and the water goes everywhere
 Post subject:
PostPosted: Wed Dec 09, 2009 9:02 pm
General Builder
leebwk wrote:
Hi Python,
Yes, we have run water into the tray and there's no leak.
Definately not the trap.
I will start from the bottom and work up, for some reason I never thought of that :oops:
 Post subject:
PostPosted: Wed Dec 09, 2009 9:04 pm
General Builder
It's definately coming from under the tray.
The tray side and skirting board are bone dry even when the corener of the floor are soaking.
 Post subject:
PostPosted: Wed Dec 09, 2009 9:06 pm
General Builder
As I say, the leak occurs when the shower is uninhabbited, also the water is definately coming from beneath the tray.
