Page 1 of 1
[ 7 posts ] |
| Author |
Message |
Andy Heather
Posted: Wed Nov 11, 2009 11:58 am |
| Newly registered Member |
Joined: Wed Nov 11, 2009 11:53 am Posts: 3 Location: chichester, west sussex Has thanked: 0 times Been thanked: 0 times
Having filled some cracks in the bathroom ceiling and allowed to dry, I used a bathroom emulsion to paint the ceiling. After a few days the emulsion cracked along the line of the original crack. Do you have any ideas why this should happen?
| Top |
doze
Posted: Wed Nov 11, 2009 12:52 pm |
| Senior Member |
Joined: Fri Dec 05, 2008 12:02 am Posts: 135 Has thanked: 0 times Been thanked: 4 times
Pics help.
Did you rake out the crack first with something sharp? Just applying filler to a ceiling crack won't work unless you've done this.
| Top |
register or
log in
Andy Heather
Posted: Wed Nov 11, 2009 2:24 pm |
Yes opened the crack first and then filled it. Looked fine until it was painted
| Top |
register or
log in
Beachcomber
Posted: Wed Nov 11, 2009 2:52 pm |
| Senior Member |
Joined: Thu Jul 30, 2009 5:26 pm Posts: 799 Has thanked: 16 times Been thanked: 55 times
What sort of filler did you use?
Could the moisture from the paint have re-activated / softened the filler?
| Top |
register or
log in
Andy Heather
Posted: Wed Nov 11, 2009 3:33 pm |
Pretty sure it was Pollyfilla - mix powder with water type.
| Top |
register or
log in
paintycait
Posted: Wed Nov 11, 2009 4:30 pm |
| Senior Member |
Joined: Mon Nov 21, 2005 11:12 pm Posts: 1352 Location: Scotland Has thanked: 4 times Been thanked: 85 times
Is there movement in the ceiling - like barewood floors upstairs that get a lot of walking on...or under a kid's bed and said child jumps off a bunk bed every morning...or somenting like that. The bunk bed thing I've had twice....first time I came across it I was flummoxed for ages - Mum had lifted the carpets and there were bare boards on the kids room. Every morning wee boy leapt from bed and thumped full force on floor. I touched up and painted that ceiling about 4 times...then I had to line it and paint it again...only way... but she paid. I told her that she either stopped her kid doing that or papered the ceiling to get rid of the cracks. 2nd time I was quicker to check upstairs before I repeatedly filled and painted.
_________________ Skilled Artisans are not cheap....Cheap artisans are not skilled. http://www.decoratescotland.comhttp://decoratescotland.blogspot.com/
| Top |
register or
log in
jozeffo
Posted: Thu Nov 12, 2009 2:57 pm |
| Senior Member |
Joined: Tue Dec 02, 2008 7:52 pm Posts: 2169 Location: South London Has thanked: 42 times Been thanked: 239 times
You could try raking out the crack and using 2 Part wood filler whicch is much stronger than powder fillers. It is a bitch to sand though and needs at least two coats.
| Top |
register or
log in
Page 1 of 1
[ 7 posts ] |
