It is currently Wed Feb 08, 2012 11:46 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 28 posts ]  Go to page 1, 2  Next
PostPosted: Fri Nov 06, 2009 7:07 pm
Bought this set yesterday at my local power tool shop AG&R in Bridgwater Somerset, cheaper than fleabay or the net. First thought prior to use was will these teeny-weeny batteries really do the job?
Anyway, had some beautiful Howden Louis hardwood (Oak) doors to fit internally today so thought I would try them out.
Firstly the drill with torque setting was amazing for all teh pilot holes and the in-built LED light was a saint when teh door was being fitted to the frame. Absolutely no problems and it seemed to go on forever. (Still drilling after using it all day!)
Next up is the impact driver. (Slow to take off when they came out but I've been a convert for a long time). Anyway, in with the bit, and screw away. Plenty of poke and not a damaged screw in sight. 10 out of 10 for both machines.
The pack comes in a simulated flight style case, with both drill and driver, a charger and two batteries.
This kit will be used a lot.
Mike
 Post subject:
PostPosted: Fri Nov 06, 2009 7:45 pm
General Builder
Been thanked: 5 times
are the batteries lithium ion?
 Post subject:
PostPosted: Fri Nov 06, 2009 7:52 pm
Sorry, that bit I meant to say ... durrr. Yes indeed Li-ion they are.
Mike
 Post subject:
PostPosted: Fri Nov 06, 2009 10:39 pm
Has thanked: 109 times
Been thanked: 405 times
so simmilar to the bosch
dead link removed
 Post subject:
PostPosted: Fri Nov 06, 2009 11:42 pm
Has thanked: 10 times
Been thanked: 108 times
I very nearly bought this kit but went with the Bosch instead, as you say it's a very useful piece of kit. I've used it a lot more than I thought I would.
Cheers,
Darren
Property Refurbishment & Maintenance Dorset
 Post subject:
PostPosted: Sat Nov 07, 2009 12:27 am
unfortunatly the above company had the progressor in a box with batts and charger
plus the impact and drill in there own little cloth casses with batteries and charger for £252 ooo such temptation :lol: :lol: :thumbright:
i then bought all the tools and the torch for £71
and ooohhh bu66er that only left the angle driver at £115 including cloth wallet charger 2 batts
now you can get the full kit cheaper than £440by a few squid but not with 6 batts and 3 chargers :wink:
ok you can get the full kit for £300
dead link removed
but thats withought 3 individual wallets 3 less batteries 2 chargers and £80 worth off cutters
anybody fancy 2 batts and a charger for half price!! :thumbright:
 Post subject:
PostPosted: Sun Nov 22, 2009 8:52 pm
Has thanked: 1 times
Been thanked: 8 times
I've been using the Makita set for just over a year. Brilliant kit but it would be nice if the batteries lasted a little longer.
Also other Makita 10.8V kit would be good ie, light, radio etc
PostPosted: Sun Jul 11, 2010 1:12 am
This kit (Makita LCT204W) comprises :
TD090DW impact driver
DF330DW driver drill.
The kit retails at about £120-£160.
Now there is a TD090DWE impact driver retailing at about £90+ and a DF330DWE driver drill retailing about £120+.
This 'E' in the model number appears to be quite significant.
Are the tools in the kit slightly lower quality than the stand-alone models?
PostPosted: Sun Jul 11, 2010 4:24 am
Has thanked: 32 times
Been thanked: 79 times
@ spekkyguy, sorry to say but the only difference between the TDO90DW & the TDO90DWE is the colour & that the TDO90DW is part of the kit LCT204W annivesary range & the TDO90DWE is a single tool with 2 1.3ah batteries and 50min charger and not part of a set and the colour change to green is just the fact that those tools are not part of the anniversary range which are coloured white there quality is exactly the same also.
For this message the author StyXSIS has received gratitude : spekkyguy
PostPosted: Mon Jul 12, 2010 7:15 pm
Has thanked: 3 times
Been thanked: 3 times
I finally got around to using mine over the last few weeks. Its eats its way through any task I've given it. The only let down is battery life but I tend not to use the impact unit so much so in effect have a spare battery on hand. I'd be tempted to pick up a spare battery anyway.
Personally wouldnt bother with any more 10.8v kit as theres much fun to be had with their 18v gear. :-)
PostPosted: Mon Jul 12, 2010 8:14 pm
with lions you just chuck them on charge when you have 10 mins
if its a 30 min charger you will get around 60% charge on a near flat battery in 10 mins
PostPosted: Thu Jul 15, 2010 6:24 am
Nah. I collect batteries like some people collect stamps. :hiding:
PostPosted: Thu Jul 15, 2010 11:12 am
join the club :thumbleft:
PostPosted: Sat Oct 16, 2010 4:49 pm
ive got this set had it for about 4 months now and i find it awsome, there not the most power full drills i have owned but small and light and usefull for fitting kitchings.
i also got the white makita site radio and i cant complain one bit about it 10/10
anyone thinking of buy it..... do it!
thanks dan.
PostPosted: Sun Oct 24, 2010 10:44 pm
I did have the pleasure of using these drills to do a bit of drylinning & really liked them especially the impact driver, but was wondering how the impact driver would fair (battery life) doing a full days work on site of plaster-boarding ?.
At the moment Im toying between buying this set because of the lightness or just buying a bare body 18v lithium impact driver seeing i already have a drill driver & batteries etc
