It is currently Wed Feb 08, 2012 6:46 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 17 posts ]  Go to page 1, 2  Next
PostPosted: Sun Oct 18, 2009 9:51 am
sorry if this question has been asked before and thanks in advance for any help....I recently had a magnaclean fitted to a Worcester 350 combi boiler and would like to clean the filter since I never got a power flush prior to installation. My question is about the isolation valves. Normally I'd turn a valve clockwise to shut it off and counterclockwise to open it but this unit has 360 degree valves (?), which means exactly what, that there's 2 open and 2 close points within the valve and it needs to only be turned a 1/4 turn in either direction to close and open? The lad ( friend of my son) who fitted it left me the small plastic wrench and told me to give it a clean every now and then but I just assumed the isolation valves worked the same as any other valve, I never heard of a 360 degree valve...can anyone explain it in simple english to this mechanically challenged OAP?
 Post subject:
PostPosted: Sun Oct 18, 2009 10:07 am
Has thanked: 43 times
Been thanked: 212 times
Firstly a Magnaclean is not a replacement for a powerflush. It is an addition to one.
You should only have to turn the isolation valves 90d to turn them off.
If you can, look closely at the silver metal showing in the edge of the valve head slot.
It actually says 'open' & 'closed'. This assumes it is a new valve with the black head.
Be prepared for a spillage of water when you release the head and also don't clean it yourself if you happen to have a pacemaker fitted.
Dave
www.drlgas.co.uk
 Post subject:
PostPosted: Sun Oct 18, 2009 10:12 am
thanks for that I'll have a look for those markings....no...no pacemaker yet.... cheers mate!
 Post subject:
PostPosted: Sun Oct 18, 2009 10:20 am
nope, had a look and can't see any markings on the valve housing, so can I assume 90 degrees to close in either direction?
 Post subject:
PostPosted: Sun Oct 18, 2009 10:44 am
OAP
Has thanked: 180 times
Been thanked: 1978 times
The handle parallel with the fitting is on.
They are 1/4 turn valves, so a 1/4 turn from where they are is off, then another 1/4 turn is on
 Post subject:
PostPosted: Sun Oct 18, 2009 10:47 am
thanks boys...got it :wink:
 Post subject:
PostPosted: Sun Oct 18, 2009 11:38 am
Mr. Grumpy
Been thanked: 32 times
Did you find much dirt in it jake?
 Post subject:
PostPosted: Sun Oct 18, 2009 11:57 am
a fair amount yeah...so I'll keep an eye on it for the next few month or so and clean it accordingly, it was just the isolation valves that threw me because there's no clear on/off markings....anything to extend the life of this central heating will do me. The lad who installed it has all his licences and put that in along with a new ch pump, sensor, and PR valve for £125, I thought that was a decent deal.
 Post subject:
PostPosted: Sun Oct 18, 2009 1:21 pm
OAP
Your joking the materials cost more than that :shock:
 Post subject:
PostPosted: Sun Oct 18, 2009 1:27 pm
Has thanked: 65 times
Been thanked: 330 times
All the units I've fitted and never thought of that :oops: thanks Dave
 Post subject:
PostPosted: Mon Oct 19, 2009 1:57 pm
I always warn customers just in case they have one fitted. I believe there is an actual warning on the box or in the instructions somewhere :?
Dave
www.drlgas.co.uk
 Post subject:
PostPosted: Tue Oct 20, 2009 2:14 pm
funny enough, the lad that fitted the magnaclean asked me exactly that (albeit with a wry smile on is face)...sorted now, thanks everyone for the replies!
 Post subject:
PostPosted: Tue Oct 20, 2009 2:21 pm
Mr. Grumpy
Heres a tip. don't dismantle it to have a look at it and leave the magnetic rod down on a biscuit tin of screws :lol: :lol:
 Post subject:
PostPosted: Sat Nov 14, 2009 10:42 am
LOL
Sorry to jump on this old thread, but I opened up my Magnaclean the other day to get rid of the crud, and it was ever so slowly still filling up. Have I done something wrong or is there a nack to it?
 Post subject:
PostPosted: Sat Nov 14, 2009 11:35 am
OAP
Probably the valve is not turned right off.
