It is currently Wed Feb 08, 2012 6:45 pm
 Post subject: Failed damp proof
PostPosted: Fri Sep 11, 2009 12:21 pm
This is my first post, be gentle with me :)
I have just bought my first home, i have just started removing the wall paper and have noticed that the walls are wet, it had a damp proof injected just over 29yrs ago and suprisingly enough the company went bust in 1988.
If i was to re-inject the walls (2 internal and 1 party) which way would be best?
I know that you can hire the machine and do it or you can get stuff in like the tubes you get selant in. But which one? also can i reuse the existing holes in the masonry or will i have to re-drill some new ones?
thanks
 Post subject:
PostPosted: Fri Sep 11, 2009 12:23 pm
Has thanked: 3 times
Been thanked: 29 times
To be honest i would get a company in to re-do it as you will get a guarantee plus the material used nowadays is far better than it used to be
 Post subject:
PostPosted: Fri Sep 11, 2009 2:52 pm
Been thanked: 14 times
It is also important to re-plaster the walls with sand/cement and added salt retarder.
 Post subject:
PostPosted: Fri Sep 11, 2009 5:16 pm
thanks for the replies, i will see how much it will cost for a specialist to do it.
 Post subject:
PostPosted: Mon Sep 21, 2009 1:39 pm
i have had an initial look at the problem, i dont think that it is rising damp, i think the it may be due to efflorescence behind the plaster attracting moisture and causing the moisture to absorb in the plaster making it damp?!
would something like this http://www.screwfix.com/prods/38631/Bui ... Seal-750ml be ok to paint on the wall then either re-plaster or dry line over the top?
thanks
 Post subject:
PostPosted: Mon Sep 21, 2009 2:18 pm
thinking about it, would this be better? http://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=10487623&fh_view_size=50&fh_location=%2f%2fcatalog01%2fen_GB&fh_search=water+seal&fh_eds=%c3%9f&fh_refview=search&ts=1253539091277&isSearch=true
