It is currently Wed Feb 08, 2012 6:25 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Loft Storage
PostPosted: Thu Sep 03, 2009 10:47 am
Hi all
I’m looking to board my loft out for storage use but I’m having a few problems deciding on a couple of things. I would really appreciate it if someone could give me a little advice as the existing joists holding the ceiling up are only 3 x 1s. The loft has a center beam running from both neighboring walls (think it’s a King pin) with the existing joists running from this to the front and back of the property. The size of the loft is 4.35m x 8.20m (with the king pin running through the centre of it).
My current plan is to use joist hangers from the king pin and use 4x2 timber (4.10m in length) running in between the old original joists. I was going to run the joists on top of the kingpin but, the floor to floor height would be too high for standard loft ladders 10.5ft and it will cut head height down significantly
My questions are:
1 – Does that sound ok?
2 – I was told 3x2 would be good enough for storage, would that be acceptable or too light?
3 – I can’t find a joist hanger to fit a 4x2, would I just use mini hangers?
I appreciate any advice any one can give
Cheers
Jacka
 Post subject:
PostPosted: Thu Sep 03, 2009 10:57 am
OAP
Has thanked: 180 times
Been thanked: 1978 times
See what the pro's have to say, but I wouldn't entertain anything less than 5 x 2 at that length.
What size is the center beam.
 Post subject:
PostPosted: Thu Sep 03, 2009 11:09 am
To be honest I haven't measured it but its about 6x4
 Post subject:
PostPosted: Thu Sep 03, 2009 11:33 am
OAP
What walls have you got supporting any of it, what is the maximum span.
 Post subject:
PostPosted: Thu Sep 03, 2009 12:23 pm
Its hard to explain really so I've attached a pic. the thin lines are the stud walls beath it
If you split the area half (either side of the kingpin) 4.1 x 4.4 one area has two stud walls beneath it and the other has has one
[IMG]http://img90.imageshack.us/img90/2809/loftfloorplan.th.png[/IMG]
[url]http://img90.imageshack.us/img90/2809/loftfloorplan.th.png[/url]
[img]http://img90.imageshack.us/img90/2809/loftfloorplan.png[/img][/img]
 Post subject:
PostPosted: Thu Sep 03, 2009 12:44 pm
not sure why that hasn't displayed
 Post subject:
PostPosted: Thu Sep 03, 2009 12:48 pm
OAP
So the maximum spam will be around 3.5m.
 Post subject:
PostPosted: Thu Sep 03, 2009 1:32 pm
[quote="thescruff"]So the maximum spam will be around 3.5m.[/quote]
Yeah I think so, on the existing joists anyway
If I put joist hangers in from the centre beam it will be 4.1m as it will be supported by the front/back wall and the centre. If that makes sense??
 Post subject:
PostPosted: Thu Sep 03, 2009 1:43 pm
OAP
See what the pros say, but I would still go for 5 x 2 minimum.
 Post subject:
PostPosted: Thu Sep 03, 2009 1:58 pm
Cheers, will do
 Post subject:
PostPosted: Fri Sep 04, 2009 2:54 pm
Has anyone else got any other opinons?
Do you think I could run a 3x2 joist over the existing joists to give me more strength?
 Post subject:
PostPosted: Fri Sep 04, 2009 8:49 pm
General Builder
Been thanked: 5 times
can you just tell me, does the large timber run down the centre of the long length or the short length?
If it's lengthways, then the span of the new timbers will be <2.2m, correct?
If that's the case, 2x4's will be more than adequate imo.
 Post subject:
PostPosted: Fri Sep 04, 2009 9:48 pm
OAP
No it goes the other way Python.
 Post subject:
PostPosted: Fri Sep 04, 2009 9:51 pm
General Builder
I don't understand this thread :scratch:
"If I put joist hangers in from the centre beam it will be 4.1m as it will be supported by the front/back wall and the centre. If that makes sense??"
please explain the bolded part jack
thanks
 Post subject:
PostPosted: Fri Sep 04, 2009 9:57 pm
OAP
You have an 8.2m x 4.35 loft area, with a 6 x 4 ish beam splitting the 8.2 in half.
The OP want to use joist hangers on the center beam and run the timber to the outside wall 4.2 isg in length.
Obviously he would need to fix a joist every 400mm centers, then board the top.
