Razor
Posted: Tue Nov 08, 2011 3:51 pm |
| Senior Member |
Joined: Wed Nov 14, 2007 10:21 pm Posts: 5141 Location: Northampton Has thanked: 76 times Been thanked: 373 times
Only diy fix is a block under the wc I'm afraid
_________________ As always help on here is free, however if you think you have saved a decent sum of money why not click the link to find out about the charity we're currently supporting? A couple of quid makes a real difference. donnas-dream-house-charity-t52110.html
| Top |
register or
log in
thescruff
Posted: Tue Nov 08, 2011 4:15 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39987 Has thanked: 187 times Been thanked: 2115 times
Looks fine to me, I would check for a partial blockage.
What size cistern is it. (Water content.)
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
1vincent
Posted: Tue Nov 08, 2011 5:09 pm |
| Newly registered Member |
Joined: Tue Mar 09, 2010 12:01 pm Posts: 13 Has thanked: 0 times Been thanked: 0 times
Thanks for replying.
There ia already a block of wood under the pan. The cistern is 9ltr. When you flush the cistern the water goes to about 2 inch's from the rim and sometimes i can hear gurgling.The water takes 30 secs to go down to normal but as said before the water level is about 5/6 inch's from the bottom of the pan. The photo doesn't see the whole of the pan as the level out of the pan outlet seems to go up a little.
| Top |
register or
log in
BillyGoat
Posted: Tue Nov 08, 2011 6:45 pm |
| Troll Headbutter |
Joined: Sat Jan 01, 2011 8:20 pm Posts: 1890 Has thanked: 77 times Been thanked: 130 times
Put another couple of blocks under, then you can dangle your legs like that bloke out of minder (pretent the toilet is giant). Write the theme tune, sing the theme tune, etc.....
| Top |
register or
log in
rovert
Posted: Tue Nov 08, 2011 8:47 pm |
| Senior Member |
Joined: Mon Nov 23, 2009 12:35 am Posts: 171 Location: Blackpool Lancs Has thanked: 7 times Been thanked: 17 times
I would suspect a blockage in the soil pipe going through the wall. A build up of carp at this point could act as a dam creating an artificialy high, standing water level in the pan base. The slightly "up hill" pan connector would make little diference to the water level. Trevor
| Top |
register or
log in
thescruff
Posted: Tue Nov 08, 2011 10:52 pm |
| OAP |
Definitely a blockage.
But first, Can you post a pic showing the side of the pan
| Top |
register or
log in
register or
log in
thescruff
Posted: Wed Nov 09, 2011 9:39 am |
| OAP |
I want the side of the pan not the waste pipe.
Can be slightly from the front.
| Top |
register or
log in
1vincent
Posted: Wed Nov 09, 2011 9:52 am |
Here's another photo. This is the best side shot i can get as the pas is only 6 inch's from the walls.
| Attachments: |
| Top |
register or
log in
thescruff
Posted: Wed Nov 09, 2011 10:03 am |
| OAP |
Good enough, I just wanted to see whether it was a siphonic pan or not.
You have a blockage.
Check the nearest inspection chamber, could also be a birds nest in the vent pipe, but check the chamber first.
| Top |
register or
log in
1vincent
Posted: Wed Nov 09, 2011 12:49 pm |
I have checked the chamber and its ok. I cant get to the top of the soil pipe to check for nests but had a look through binoculars and no signs of a nest.
| Top |
register or
log in
thescruff
Posted: Wed Nov 09, 2011 12:55 pm |
| OAP |
You could try flexible rods towards the stack.
| Top |
register or
log in
1vincent
Posted: Thu Nov 10, 2011 8:12 am |
I dont have any rods to try that idea out. Is there anything else i could try or will i have to take off the cister and pan and have a look?
| Top |
register or
log in
Aged P
Posted: Thu Nov 10, 2011 9:38 am |
Joined: Thu Mar 10, 2011 5:08 pm Posts: 3 Has thanked: 0 times Been thanked: 1 times
I would give the pan a good old plunging with a floor mop and see how it goes from there
| Top |
register or
log in
