It is currently Fri May 25, 2012 9:27 pm
 Post subject: toilet flush groan?
PostPosted: Fri Dec 02, 2011 2:14 am
Has thanked: 7 times
sounds really weird but the toilet cistern has developed a strange groaning noise every time you flush :wtf: ....does anyone know what is causing this noise and how can I fix it-i.e. stop the noise from happening every time I flush? the toilet is in a ground floor cloakroom and has been working fine for the last 10 years.
I would be grateful for some advice regarding the problem....thank you
thanx.....!
 Post subject: Re: toilet flush groan?
PostPosted: Fri Dec 02, 2011 9:39 am
OAP
Has thanked: 187 times
Been thanked: 2115 times
Plastic ballvalve. :thumbright:
Change the diaphragm washer.
PostPosted: Fri Dec 02, 2011 11:47 am
Thank you for the response...exactly where is the diaphragm washer located?
thanx.....!
PostPosted: Fri Dec 02, 2011 11:58 am
OAP
In the ballvalve
You need to turn the water off, and undo the small nut to remove the valve body, you can then undo the larger nut to get at the washer.
ps, Don't loose the fibre washer.
PostPosted: Sun Dec 04, 2011 7:32 pm
Thank you for all the info...will give it a go. Do I simply replace the old washer for a new one, which will stop the noise? Is the damaged washer made from rubber/metal?
thanx.....!
PostPosted: Sun Dec 04, 2011 7:34 pm
OAP
Yes changing the washer will stop the noise.
They are a rubber possibly epdm
Users browsing this forum: No registered users and 8 guests
