Page 1 of 1
[ 12 posts ] |
| Author |
Message |
splash
Posted: Sun Jan 01, 2012 3:33 pm |
| Newly registered Member |
Joined: Sun Jan 01, 2012 3:20 pm Posts: 5 Has thanked: 5 times Been thanked: 0 times
Hi all, hope someone can help with my problem.
We moved into this new build house 5 years ago, all well with toilets until yesterday.
After flushing the toilet the cistern won't stop filling and waste water is going down the overflow and into the toilet pan. It is a SIAMP. The plastic float does not rise when the water reaches it, instead it just stays down so the water keeps coming into the cistern. However, I can raise the float quite easily by hand and when I do that and apply quite a lot of manual pressure the flow of water stops.
The float doesn't seem to be catching on the side of the cistern so I'm a bit baffled.
I have no plumbing knowledge but would like to have a go at sorting it out myself if poss.
All advice gratefully received. Thanks in advance.
| Top |
Inky Pete
Posted: Sun Jan 01, 2012 3:46 pm |
| Senior Member |
Joined: Fri Feb 03, 2006 2:34 pm Posts: 1206 Location: Cheshire Has thanked: 6 times Been thanked: 85 times
Can you remove the float from the cistern and check that it actually does. Float, that is.
It could have a hole in it which has caused it to fill with water.
| Top |
register or
log in
splash
Posted: Sun Jan 01, 2012 4:41 pm |
Hi, thanks for your reply.
I follow your logic but I can tell without dismantling it that it's not full of water.
We have an identical toilet upstairs which works fine. On that one I can pop the float down with my finger and when the cistern fills the float pops back up, as you would expect. With the faulty one the float doesn't move when the water rises, it just sits there and the cistern keeps filling. I can pull the float up with my hands and by exerting pressure (ie pulling it up) I can stop the cistern filling. If I then flush the toilet the cistern doesn't fill unless I push the float down again.
You would think the float was snagging against the cistern to stop it rising and falling but it's clear of the cistern.
Any more ideas folks?
| Top |
register or
log in
thescruff
Posted: Sun Jan 01, 2012 4:46 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39987 Has thanked: 187 times Been thanked: 2115 times
Probable wants a new one.
Have you stripped it down to see if there's something broken.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
splash
Posted: Sun Jan 01, 2012 4:59 pm |
Thanks for that.
Will have a go at that in the morning. Have no knowledge of plumbing whatsoever. Will shut off water supply, flush cistern, then try to work out how to dismantle it. Any tips/advice on how to do that will be very welcome!
| Top |
register or
log in
thescruff
Posted: Sun Jan 01, 2012 5:03 pm |
| OAP |
Never had the pleasure of taking one to bits but it should be obvious if you take your time.
| Top |
register or
log in
register or
log in
register or
log in
splash
Posted: Mon Jan 02, 2012 2:34 pm |
Many thanks for those replies. I will have a go.
| Top |
register or
log in
splash
Posted: Wed Jan 04, 2012 7:06 pm |
Just a quick post to say that I dismantled it following the instructions given on the Siamp website you directed me to and it worked!
Massive thanks to all who replied. I'm sure this wouldn't be a big deal to you experienced DIY'ers but not being someone who has ever done any successful DIY I'm pretty chuffed to be honest.
Thanks again.
| Top |
register or
log in
register or
log in
Brox Boy
Posted: Sun Mar 04, 2012 9:07 pm |
Joined: Sun Mar 04, 2012 8:51 pm Posts: 1 Has thanked: 0 times Been thanked: 0 times
I have a similiar problem to the one above. Water wil not stop running into the toilet. I have done all of the above but still no change. What I have done though is adjust the height of the float and made matters worse and I cannot get it back to what it as, until I messed about with it the water ran into the toilet for about 30 seconds.
Can anyone help.
| Top |
register or
log in
Page 1 of 1
[ 12 posts ] |
