It is currently Wed Jan 23, 2019 8:09 pm
PostPosted: Sat May 26, 2018 8:18 am
Has thanked: 35 times
Been thanked: 1 times
…that is the question!
The interior of my small 6ft x 4ft shed at present...
I don't plan on heating the shed but it is essential that the humidity level remains very low, a dessicant de-humidifier will be purchased on completion of the project.
The interior will be clad in plywood and all joins/gaps sealed with frame sealer. However should I insulate in between the studs, floor and roof beforehand? I'm thinking not since there's no plans to heat the area.
PostPosted: Sat May 26, 2018 9:38 am
Has thanked: 627 times
Been thanked: 1795 times
May I suggest that, if you can lift it, to slide some damp course membrane under the floor supports to protect from moisture. See https://www.wickes.co.uk/Wickes-Damp-Pr ... m/p/133880
As for insulation I think it is only any use if you heat it and the insulation retains the heat. The ambient air will settle to the temperature and humidity it decides.
Painting with BIN
PostPosted: Sat May 26, 2018 10:05 am
Has thanked: 349 times
Been thanked: 1811 times
No insulation and it'll be hot in summer, cold in winter. If you want a 'steady' temperature then slap a roll of insulation in. A single roll at around £15 would easily do it - cheap enough to not worry over, lots more complicated if you change your mind in the future - as everyone inevitably does!
and I 'second' DWD's recommendation for DPM.
PostPosted: Sat May 26, 2018 10:15 am
My mistake, I should've stated that a 1200 DPM will be used underneath the floating floor before affixing plywodd to the top.
PostPosted: Sat May 26, 2018 10:25 am
The temperature isn't really an issue, one large or two smaller compressors a fuse board or junction box (a shed for storage only). What is a concern is humidty but I figure a de-humidifier would take of that. Insulation won't assist in reducing humidty in these circumstances?
PostPosted: Sat May 26, 2018 11:07 am
Has thanked: 999 times
Been thanked: 1878 times
If you aren’t going to introduce heat to the building then it’s a waste of time insulating the shed.
It’s worth sticking a small vent in tho to keep the place ventilated.
PostPosted: Sat May 26, 2018 12:36 pm
Has thanked: 45 times
Been thanked: 725 times
Insulation won't affect humidity at all and if you are not heating it then it will not have any effect either. How do you plan on sealing it up though? Dehumidifiers will be pointless if there is easy air infiltration, you need a sealed space really.
Also, why is humidity an issue, you mention compressors in there, what exactly are you using the shed for?
PostPosted: Sat May 26, 2018 1:19 pm
Noted, thanks for the info :)
The Vent will be a bad idea, steel an iron tools will rust. I have two sheds already that are ventilated.
PostPosted: Sat May 26, 2018 1:25 pm
Every timber you have down already should be sitting on a dpc. I’m assuming you aren’t planning on putting the 1200 Dpm on top of what’s already down?
PostPosted: Sat May 26, 2018 1:28 pm
The framework sits on 20mm x 60mm nylon blocks spaced at various intervals, this keeps the timbers dry. The floating floor framework will rest on the 1200 gauge DPM
PostPosted: Sat May 26, 2018 1:36 pm
I'm think of entering the blow up dolly industry, hence the need for air compressors ;)
Planning on using Dow Corning 791 or some other frame sealer for sealing all the joins between the plywood. Predominantly automotive bodywork will be undertaken in a far larger shed adjacent to this little one
PostPosted: Sat May 26, 2018 1:51 pm
Ah spraying. The dehumidifiers will be pointless then. You will need ventilation for the compressors and they will draw in moist air from outside much faster than the dehumidifers can dry it out. Better investing your money in a drier to use on the compressed air itself.
Run the air through a double moisture trap/filter and then either a desiccant or refrigerant drier, you will get much better results.
PostPosted: Sat May 26, 2018 1:57 pm
I'll just open the shed door when the compressors are in usage. When they're are not and which could be for long periods the de humidifier will keep the humidity low and the tools alongside the compressors rust free.
A drier is a good idea, but price wise is far more expensive than a small dessicant de humidifier. Also, and I've made one already, if only painting small quantities of body panels a simple dog leg copper pipe system works well enough as a moisture trap along with the filters I have.
PostPosted: Sat May 26, 2018 3:05 pm
Ok, the dehumidifier will help keep things rust free but will not do anything to help dry the air for spraying.
