It is currently Sat Jul 21, 2018 7:00 am
PostPosted: Mon Oct 23, 2017 9:24 am
Has thanked: 7 times
Been thanked: 3 times
hi
we have Ideal Logic+
there is a slight leak (about a pint a week) from one of the pipes connected to the boiler
downloaded manual: http://www.freeboilermanuals.com/assets/pdf/ideal/204978.pdf
on page 34, section 37, identified that the leak comes from DHW outlet
there is quite a bit of residue on the nut and the pipe, also cabinets underneath are rotten - i think it was leaking for years.
i would just undo the nut, clean the thread, put some tape around it and screw back on.
is this the way to do it??
is the pipe pressurized? if it is, do i shut the mains or should there be an isolation valve somewhere?
thank you in advance!
michael
PostPosted: Mon Oct 23, 2017 3:31 pm
Has thanked: 811 times
Been thanked: 886 times
Turn off cold mains inlet under the boiler.
Open a hot tap lower than the boiler and leave it open.
Undo nut on hot water pipe, replace 1/2" fibre washer and tighten up.
Dave
www.drlgas.co.uk
For this message the author gas4you has received thanks - 2: michaelp, multiman
PostPosted: Tue Oct 24, 2017 10:39 pm
Has thanked: 696 times
Been thanked: 28 times
^ what he said cause will be a damaged washer mostly caused by over tight of nut.
For this message the author multiman has received gratitude : michaelp
PostPosted: Wed Nov 01, 2017 3:00 pm
AND don't let your girlfriend open a mixer tap in the bathroom while you are replacing the washer
LOL, she did just that...
all done, thanks! £70+vat saved :-)
For this message the author michaelp has received thanks - 2: gas4you, multiman
