It is currently Fri May 25, 2012 7:09 pm
PostPosted: Thu May 29, 2008 8:09 pm
One thing that is bugging me: if I am using waterproof plasterboard (Knauf) in bathrooms, presumably I do not need to Tank it and could(?) apply the tile adhesive straight onto it. But how can the paper support the tiles? If I stick a piece of masking tape on it and pull it, it will pull the paper easily.
 Post subject:
PostPosted: Thu May 29, 2008 8:43 pm
Has thanked: 127 times
Been thanked: 392 times
If it is being used in a shower area, then it would be best to tank it first.
The paper supports the tiles because it is all bonded together, if you use a piece of masking tape it does not cover a large surface area, like a wall full of tiles would do.
You can see the weights that certain substrates can support here-
Wall tiling
Correctly braced aquapanel can supporg 50kg per square meter :wink:
DIY | Donnas dream house
 Post subject:
PostPosted: Mon Jun 02, 2008 9:27 am
i saw my builder tiling on waterproof plyboard is that normal (obviously he put PVA first) is that ok for the bathroom? (it is a partition wall)
 Post subject:
PostPosted: Mon Jun 02, 2008 5:47 pm
He should not of used the PVA, unless it was external PVA. Chances are it will be ok, unless the area gets really wet-
http://www.ultimatehandyman.co.uk/tilin ... se_pva.htm
