It is currently Fri May 25, 2012 7:09 pm
 Post subject: Tiling on render
PostPosted: Mon Jun 30, 2008 8:08 am
Has thanked: 3 times
Been thanked: 18 times
Recessed fireplace with small wood burner approx 5'w 2'd 4'h with a 6" border onto wall. Back is to be left in natural stone, sides and border to be tiled. Client has 60mm x 30mm x 10mm tiles.
What prep should I do on the cement render (done last year so completely dry) and any advice on fitting these large tiles.
Any tips gratefully received.
 Post subject:
PostPosted: Mon Jun 30, 2008 6:46 pm
Has thanked: 127 times
Been thanked: 392 times
Hmm, are you being sarcastic about the size of the tiles or else are they the 600mm ones ?
I'd just seal the render with which ever primer your adhesive manufacturer recommends and then get tiling :wink:
DIY | Donnas dream house
 Post subject:
PostPosted: Tue Jul 01, 2008 7:49 am
Sorry, me & metric - 600 x 300 x 10!
Not the ideal size for the job but the Wifie has a whole stack of these as a freebie.
Just that I've come across references to tile weight vs substrate though logically cement render should hold most anything.
 Post subject:
PostPosted: Tue Jul 01, 2008 4:53 pm
sand and cement render can hold approx 32kg per square meter and so should be ok.
You might have a lot of cutting to do with such large tiles.
 Post subject:
PostPosted: Wed Jul 02, 2008 7:49 am
Thanks, not particularly looking forward to this one but its an open door to a ton of work so well worth the effort.
