It is currently Fri May 25, 2012 7:05 pm
PostPosted: Wed Jun 15, 2011 1:51 am
Has thanked: 4 times
Hi
I need to add a shower into a room. The two side walls will be completely new, so will be built from studwork and aquapanel. The backwall is currently a bare brick wall, which is beautifully laid with clean, sound, dry bricks. (It is external cavity wall if that makes any difference). Can I tile directly to brickwork or should I aquapanel the back too?
Thanks in advance.
Stan
PostPosted: Thu Jun 16, 2011 8:42 am
Anyone :help:
PostPosted: Thu Jun 16, 2011 9:29 am
Has thanked: 20 times
Been thanked: 45 times
I'm sure you 'can' tile brick but, personally, I'd aquapanel it mate. :scratch: Don't think you can just dot and dab it - so I'd mechanically fix as well. If the whole enclosure is aquapanel, you're just not going to get any problems :thumbleft:
JC DIY Blog
PostPosted: Thu Jun 16, 2011 9:37 am
Has thanked: 17 times
Been thanked: 265 times
I would also go with Aquapanel. Have a look at this http://www.teachmediy.co.uk/NetsiteCMS/ ... panel.html
:thumbright:
For this message the author dewaltdisney has received thanks - 2: edengarden, root
PostPosted: Thu Jun 16, 2011 10:47 am
Thanks for your comments - much appreciated. Looks like more aquapanel then.
Stan
