Page 1 of 1
[ 8 posts ] |
| Author |
Message |
COSMICSUN
Posted: Tue Mar 22, 2011 11:35 am |
| Newly registered Member |
Joined: Thu Jun 10, 2010 9:41 am Posts: 18 Location: LANCASHIRE Has thanked: 8 times Been thanked: 0 times
Could some one answer my query please. I want to tile my bathroom, and would like to fully tile behind my toilet. which means having to remove the cistern and attached basin out of the way. my question is.? when i put my toilet back will the extra 8mm or so thickness of the wall make a difference with sealing the drain outlet. ie, when i put it back will it leak at the outlet or will i get away with it. i also what to lift the toilet up some 10mm at the same time because of a new floor. please can anyone help or would it be best to post this question in the plumbing forum.. my many thanks in advance COSMIC ps not sure how much movement have in the waste pipe if any..
| Top |
thescruff
Posted: Tue Mar 22, 2011 11:40 am |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39987 Has thanked: 187 times Been thanked: 2115 times
There will be a way of doing what you want, how or what fittings you'll need will depend on the existing.
Perhaps a pic or two
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
COSMICSUN
Posted: Tue Mar 22, 2011 11:55 am |
THANKS, I Will try and put a picture on for you to see, but my quest is not to have buy or replace the wide waste pipe going though the wall.. cheers..COSMIC.
| Top |
register or
log in
thescruff
Posted: Tue Mar 22, 2011 12:14 pm |
| OAP |
You will find an offset pan connector may be the best fitting to swing the connection to the higher level
| Top |
register or
log in
COSMICSUN
Posted: Tue Mar 22, 2011 12:34 pm |
HI SCRUFF. THANKS AGAIN. I Think I have seen one of these, is it little a Constantina type connector, that slips over the toilet outlet and waste pipe. ??. could I ask you where is in your opinion is the best place to buy one from, and have you any idea of the price of these things. not that i am skint and a cheap state .lol. but i don't like paying the big DIY store prices if i can get on much more reasonable. and SCRUFF.. MANY MANY THANKS TO YOU IN DEED.
| Top |
register or
log in
register or
log in
COSMICSUN
Posted: Tue Mar 22, 2011 1:02 pm |
SCRUFF. YOU ARE A MEGA STAR, JUST WHAT THE DR ORDERED. THANK YOU SO MUCH FOR YOUR TIME AND INTEREST YOU HAVE BEEN EXTREMELY HELPFUL. TOP MAN. INDEED .. COSMIC.
| Top |
register or
log in
thescruff
Posted: Tue Mar 22, 2011 1:42 pm |
| OAP |
No probs, it's easy when you know whats available.
| Top |
register or
log in
Page 1 of 1
[ 8 posts ] |
