Page 1 of 1
[ 8 posts ] |
| Author |
Message |
harrison
Posted: Wed Jul 21, 2010 12:13 am |
| Newly registered Member |
Joined: Wed Jul 21, 2010 12:02 am Posts: 3 Has thanked: 0 times Been thanked: 0 times
Hi, I have a problem that I need some professional advice for. I am installing a new bathroom in a 400 year old cottage.
We have a "freestanding" resin bath from the Bathstore, the model is "Norfolk" designed to fit in a corner i.e. it is flat on one side and on the tap end so it can be tiled to. The issue I have is - do I tile the walls first and then install the bath and seal to the solid tiles or do I tile "down" onto the bath having tiled below and behind it first and then seal the bath so it is effectively set in to the tiles. Obviously being freestanding I need the tiles to go to the floor on both the side and end but I am most concerned about getting an effective seal as there is also a shower above.
I have looked at many different fora and seen advice which suggests both but have not found anything specific to this type of bath. Also should I put a batten below the straight edge to support - but this would be visible and ruin the look etc. I am aware of tips such as filling with water to seal etc
One point - the walls are not dead plumb as they had old tiles on which we have removed and made good any damage - they are not bad but are not as true as new build, any advice welcome.
| Top |
thescruff
Posted: Wed Jul 21, 2010 12:33 am |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39133 Has thanked: 181 times Been thanked: 1983 times
The norfolk is a range of baths, do you know the actual model.
_________________ --------------------------------------------------------------------------------------------------- If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
thescruff
Posted: Wed Jul 21, 2010 12:39 am |
| OAP |
Probably this one.
In which case I would tile all the wall first.
If the floor is tiled you may want to consider sticking the feet down, with something to stop them moving about. Silicon would probably do the job.
| Top |
register or
log in
tictic
Posted: Wed Jul 21, 2010 1:05 am |
| Senior Member |
Joined: Fri Sep 25, 2009 7:09 pm Posts: 439 Has thanked: 2 times Been thanked: 17 times
as above...
| Top |
register or
log in
harrison
Posted: Wed Jul 21, 2010 8:58 pm |
Thanks for this so :- tile the walls completely then silicon seal the bath to the tiles. Do I "fix" the bath first with sealant, and then seal the gap or do this in one hit.
The floor is new timber floorboards and the feet are strange, they are man made (maybe a resin compoiund) instructions say screw/bolt the feet to the floor but there is no hole to do this - although there is a small outline that suggests maybe you are meant to drill them yourself - any thoughts on that also approciated if anybody has seen thois type of foot before.
| Top |
register or
log in
thescruff
Posted: Wed Jul 21, 2010 9:24 pm |
| OAP |
If you have a groove in the feet for fixing, then use them with some big washers before you seal the bath to the tiles.
Make sure there's no pipes etc in the way.
| Top |
register or
log in
harrison
Posted: Wed Jul 21, 2010 10:23 pm |
Hi - sorry but there is no groove at all just a small outline on the inner side of the foot that I am guessing suggests drilling but other than that they are solid - I could always gripfill them straight to the floor ( No More Nails or other product maybe?)
| Top |
register or
log in
thescruff
Posted: Wed Jul 21, 2010 10:27 pm |
| OAP |
Can you post a pic of the feet.
| Top |
register or
log in
Page 1 of 1
[ 8 posts ] |
